fatdaz
Problem?.....Bad earth????
my rado g60, when im driving the stereo will cut off and then come back on, and bleep like when u switch the igintion off,
also ive noticed sometimes the passenger side headlight will come on and off when it feels like it?!!!! lol
is this a bad earth? anyone experienced similar problems before or know what it could be?
cheers
daz
go to VW, they're only £20ish... Don't bother with the GSF/Eurocarparts ones as they're not as good as the VW ones...
had the same and it was the IS
Also had the same and it turns out my upper steering colomn bearing had lost a few of its ball bearings and they were floating around beind the trim shorting stuff out. took nearly a yr to sus it as there was no play in the wheel.
that mostly blew fuse too though
thanks for info guys :)
dnt suppose anyone knows the part number do they? my local dealers are far from helpfull unless i have a part number :p
