gollfy 0 Posted October 13, 2006 I have a standard 1995 2.0 8v rado and just need to know the size of the brake discs that fit it:) are they 280mm? Thanks all Quote Share this post Link to post Share on other sites
Yandards 0 Posted October 13, 2006 Er, should be 256mm. Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 13, 2006 Er, should be 256mm. yep 256 as standard, you could always measure yours :wink: only confusion with a motor factors might be that the 2L 8v engine was used on the mk3 golf and that had 280mm brakes (but 5 stud). AFAIK the only vws with 4 stud 280's were the G60 corrado, rare G60 golf and even rarer G60 passats. Quote Share this post Link to post Share on other sites
Crasher 4 Posted October 14, 2006 And the Rallye also used the 535 615 301, 4 x 100 M12 PCD 280x22 disc. Quote Share this post Link to post Share on other sites
