Tekara 0 Posted October 31, 2006 Looking some advice in connection with changing the clutch slave. Problem ive got is the hydraulic line into the slave refuses to budge, ive covered it in numerous liberal applications of WD40 and left for some time and still wont loosen. It reached a point where it feels like the hex might round off. Does anyone have any tips on how to loosen it off so as to save it for reuse. If its not going to come off without force, how far back up the line would i have to replace. Any help would be greatly appreciated Quote Share this post Link to post Share on other sites
Crasher 4 Posted November 1, 2006 You may have to cut it off and fit a new hose/pipe with the new slave and the hose/pipe part number is 357 721 465 A, about £38. The hose goes up to the inner wing where it joins a solid pipe along to the master cylinder and if you are unlucky enough for that to also fail, you will need 536 721 477 A, about £17. Quote Share this post Link to post Share on other sites
