Riley 0 Posted November 7, 2006 Ok guys heres the problem, The spoiler used to be intermittent with speed,always worked on the switch. New relay jobbie and it worked at speed for a while :D But now... If i have the lights on,it dosnt come up at speed,or it sort of jumps up and down. And ! sometimes lights on or off,it dosnt come up at speed unless i stab the throttle over 45mph :? ! Ive gone through all engine bay earths,tailgate wiring,the new relay,even a new speed sensor in the gear box :? Any idea's guys? Neil. Quote Share this post Link to post Share on other sites
nocrap 0 Posted November 7, 2006 sort of jumping up and down would indicate to me that the relay is switching one way then the other as if there isn't enough voltage............. Quote Share this post Link to post Share on other sites
Riley 0 Posted November 10, 2006 Sounds plausable m8,where would i start looking? It does seem worse if i have plenty leccy bits turned on... Its really annoying me now,i keep putting it up with the switch everytime i drive just so it dosnt look p|ssed :( What components are there in the set up? the control module. the switch. does the speed sensor in the gearbox actually have anything to do with it? anything else? like on the clocks themselves etc etc? Cheers,Neil. :) Quote Share this post Link to post Share on other sites
Riley 0 Posted November 11, 2006 Bump,may have a look at erm..... 'something' tommorow? :? :lol: Quote Share this post Link to post Share on other sites
Riley 0 Posted November 15, 2006 Any idea's guys? :? Would it be worth swapping the fuse box for a spare i have? Neil. Quote Share this post Link to post Share on other sites
Riley 0 Posted November 26, 2006 Any idea's guys? :( Quote Share this post Link to post Share on other sites
Riley 0 Posted December 4, 2006 Still doing this :( Does seem like low voltage somehow :? Quote Share this post Link to post Share on other sites
mrbeige 0 Posted December 4, 2006 The clocks send a signal out to the spoiler control module, so they do play a big part in the spoiler operation. Your issue doesn't sound like a clock issue though to be fair, but if you like I can have a look at them?? Quote Share this post Link to post Share on other sites
Riley 0 Posted January 29, 2007 Cheers Mrb,would that involve sending the clocks to you? would you know what to look at? Its still doing it :( Whats weird is that i can trundle along at over 45mph or more without the spoiler coming up,but if i let off the throttle and stab it back down again,the spoiler comes up :? Or if i just plant the throttle,it comes up... Would love to have it working reliably...only thing thats not working at the moment! :lol: Oh,what about the sensor in the gear box? nowt to do with it? Neil. Quote Share this post Link to post Share on other sites
Karoliz 0 Posted June 20, 2007 Didn't want to create new topic -so here's the problem: Spoiler worked perfectly - till yesterday... I've just started the car and spoiler came up - now its rised and not moving down when pushing spoiler control button... What might be the problem? -The button, relay, sth else?... Quote Share this post Link to post Share on other sites
iverrado! 0 Posted June 22, 2007 Hi there if your still having probs with your spoiler you might want to check the micro switches under the cover behind the manual control knob which is a spline fit so just needs a good pull to remove it, then its just a case of removing the black cover by undoing the 3 bolts and the various clips round the outside that hold it in place. Make sure the 2 racks that drive the spoiler dont fall out as its upside down if done on the car. With the cover removed there should be 2 blue oblong shaped micro switches. To test them just press on the white nylon button if it clicks its ok if not then that could be the problem. They can be fixed but this is only a short term solution and quite fiddley. The cost for the unit from VW is about £270 but im sure if you go to a place like maplin they might be able to help or an electrical wholesaler. Hope this helps. Ade. P.S this is alot easier when the whole thing is removed from the car. Quote Share this post Link to post Share on other sites
