iggi 0 Posted November 20, 2006 as i look at the distributor on a 16v, starting top left and goin anti clockwise, what order are the plug leads. been told 2 different! also the dam mixture screw ontop of airbox. which way is richer, which is leaner??? any help. cheers! Quote Share this post Link to post Share on other sites
Crasher 3 Posted November 20, 2006 Look on the distributor body top edge with the cap off and you will see a small notch, which is number one. Put the cap back on and look for the lead that corresponds to that notch and then follow the arrow on the outside of the distributor body in the firing order 1, 3, 4, 2. If someone has told you 1, 4, 3, 2, that is for the flat four motor. The mixture is enriched by turning the screw clockwise. Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 20, 2006 rightie richie ...lefty leanie Quote Share this post Link to post Share on other sites
ben16v 0 Posted November 20, 2006 Quote rightie richie ...lefty leanie :lol: Quote Share this post Link to post Share on other sites
Crasher 3 Posted November 20, 2006 Not if it's a 2E2 Pierburg carb! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 20, 2006 Crasher said: Not if it's a 2E2 Pierburg carb! Another one to add to the swear filter... Not on here please Steve! - thats got to be one of the worst bits of kit fitted by VW on a car... Quote Share this post Link to post Share on other sites
Crasher 3 Posted November 21, 2006 What, Pierburg :2gunfire: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 21, 2006 The 2e2 / 2e3 Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 21, 2006 Supercharged said: The 2e2 / 2e3 why cant you fix those either :lol: :lol: hows the g60 running :roll: Quote Share this post Link to post Share on other sites
TomD 0 Posted November 21, 2006 Sorry for the cheeky thread high jack... ...is the screw that also has a 6mm hex head on it on the back of the G60 throttle body a mixture screw or an idle screw? I've been fiddling with it and am not sure whether I should have done now! :oops: Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 21, 2006 TomD said: Sorry for the cheeky thread high jack... ...is the screw that also has a 6mm hex head on it on the back of the G60 throttle body a mixture screw or an idle screw? I've been fiddling with it and am not sure whether I should have done now! :oops: its the idle.....ajusted with the bts disconected Quote Share this post Link to post Share on other sites
TomD 0 Posted November 21, 2006 steveo29 said: TomD said: Sorry for the cheeky thread high jack... ...is the screw that also has a 6mm hex head on it on the back of the G60 throttle body a mixture screw or an idle screw? I've been fiddling with it and am not sure whether I should have done now! :oops: its the idle.....ajusted with the bts disconected bts....is that blue temp sensor? If so...hurrah... I did it properly! :) Cheers! :) Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 21, 2006 yeah blue temp sender Quote Share this post Link to post Share on other sites
