VRTrickster
Dodgy Windscreen
Right I had my screen replaced a couple of years ago now, and it was replaced with an after market Pilkington. It was also fitted with a horrible universal rubber seal, that was hanging off in till I got the cowboy back!
The trouble is now I want to put a genuine Sekurit screen, and proper seal back in. I need to Know everything I need to replace to fit the original type back in?
Will I just need the outer rubber seal,as the screen comes with the rest shown on ETKA?
Can anyone help me on this one?
Yeah - Screen comes with the 3 black bits of trim at the bottom...
You will also need the white clips that they go into i think - 11 all together...
Seal is about £28
You may also need some spacer things but the glass fitter should have these...
Best to get it all done on insurance really... (ie buy a hammer and a punch)
Alright ok so Ill order -
535 853 307 A (UPPER TRIM MOULDING)
535 845 127 A (RUBBER STRIP)
443 845 635 A (DISTANCE PIECES)
Cheers Supercharged, I cant seem to find these clips your on about in Etka?
I need to make sure I have everything there for the fitter! Im going to make sure they send someone that doesnt mind being watched also, lol !
Its that some of the mouldings are reused, and mine have been thrown away by the cowboy!
I suppose I could let the screen company know that it needs all the seals replacing, but I dont know how far they will go ?
If you go somewhere decent like RAC or Autowindscreens, they should have all the parts necessary - if not, then they'll be able to get hold of them...
