iow_corrado_g60 0 Posted January 30, 2007 Hi all can someone please assist have a 95m VR6 mk3 golf the problem is the horn isn't working cheacked all fuses etc all fine! it had a standard steering wheel has anyone got any ideas. Cheers in advance Andy Quote Share this post Link to post Share on other sites
nocrap 0 Posted January 30, 2007 Check both contact connections under the horn push, it should just pull up... Quote Share this post Link to post Share on other sites
khurrado 0 Posted January 30, 2007 check the horn wiring in the steering wheel. Mine used to always come off, which made road rage incidents even more infuriating. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 30, 2007 i'd check the horn on the battery first , before getting too involved make sure it actually works Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 30, 2007 Have you tried pornography? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted January 30, 2007 Have you tried pornography? lmao :-) viagra ? Quote Share this post Link to post Share on other sites
penfoldvr6 0 Posted January 31, 2007 little blue pills.....give u the horn :twisted: :crazyeyes: Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted February 26, 2007 hi guys just to bring this back up its defdo not connection on the steering wheel as when i push the horn from both sides i can hear the actuator near the fuse box clicking like it does for the window wipers etc. so any other ideas where is the horn and how do i test now! thanks Andy Quote Share this post Link to post Share on other sites
Walesy 0 Posted February 26, 2007 Have you checked the fuse ? And I assume you have an airbag in your car do you dude? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted February 26, 2007 hi walesy hows you? I've checked all fuses mate! have a passenger air bag not sure if theres one in the steering whell but its a standard vag wheel so i guess there is! Quote Share this post Link to post Share on other sites
