H9 DUB 0 Posted June 25, 2007 NICE! these turned out really well, looks like i not the only one with speedies that need a refurb :) Quote Share this post Link to post Share on other sites
cvw 0 Posted August 1, 2007 just read this thread and am impressed with the handywork displayed but how do we go about sorting out kerb marks out without ruining the wheel. cheers grease monkeys. Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted August 7, 2007 i recently helped a mate refurb a set of alfa romeo teledials that were kerbed to hell. to rebuild the lip of the rim, we found a bit of a rim that was undamaged, then used the Metalic version of p38 filler to make a "mould" that we could use to reform the edge of the rim. we carefully layed selotape over a good bit of rim, then made a golfball size blob of filler and moulded it round the selotape and let it set, then took it off. then whe we put the metla filler on the rim, we could skim it round with our little mould and it matched the profile of the lip perfectly, very little sanding was needed after :) not sure how durable it will be but hes always mega careful with kerbs so it shouldnt matter too much ;) we then primered up the rim with etch primer and painted+laquered. before: after: on the car: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 7, 2007 good job, looks neat. Just in the middle of doing mine. Started the one wheel (at the mo) on sunday, sanded it down filled any kerbing and primed. Got the Wurth paint through today, just giving it a couple of coats. Is it recommended the paint stage is sanded using 1200 wet and dry before lacquering? Has anyone attempted doing the inside of the wheels too, or just stuck to refurbing the face? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 8, 2007 Is this thread still been watched? May be a daft Q but can the lacquered surface be 1200 wet and dried before a final coat of lacquer is added? Quote Share this post Link to post Share on other sites
djmac56 0 Posted August 8, 2007 Hi CM, I'm pretty sure that's a no - you need to use thinners to take it off if you FUBAR it! Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted August 8, 2007 i would never sand a basecoat surface before i laquered it- and you should generally apply the laquer no more than 2 hours after the basecoat is applied (ie before its cured fully) so it adheres properly. Otherwise you're more likely to get issues with the laquer lifting over time and getting white watermarks behind it. Quote Share this post Link to post Share on other sites
