VRTrickster
What Oil Pressure VR6 ? (Retested)
Can someone please tell me what sort of pressure I should have at 2000 rpm? And what is the Maximum Im likely to see at say 4000-5000?
That would be great cheers !
Warmed up or not?
At idle I see 4 bar when cold, within a few minutes its down to 2 bar and when fully warmed up it will sit between 0.5 and 1 bar at idle.
doing steady 70-90 in 5th (circa 3K+ rpm) when fully warmed up will also see around 4 bar oil pressure
generally try and always keep oil press below 6bar until its warmed up...
can't recall what the pressure was at 5-6K rpm though..sorry
Should I be seeing 8-9 bar hot or cold at 3-4k ?
Cold, yes, it's possible.
Hot, no.
If you've got the VDO gaugaes, your pressure Sender is f'cked basically, or has dirty contacts.
8-9 bar at 3-4K rpm- To reiterate the above, cold- yes you cold easily see that, warm- no- mine probably sits between 4 and 5 at those rpm warmed up.
Hopefully its your pressure sender playing up ;)
Im sure when I tested it at around 70 degrees, idle was around 2bar then revving it to 2500-3000 it hit the end of the gauge, 10bar gauge a think! The pressure seems to rise fairly rapid with the revs.
I was thinking what would the pressure be at 4-6k ? !
Right well I done a retest this evening and I think all is well!
Engine nice and hot, idle was just above 2bar, increasing to 2000rpm it raised smoothly to about 3.5bar and around 3-5 at 3000 ish.
I guess everything's pretty normal then ?
Oh and the gauge is only 8bar, so I was getting worried over nothing lol! :roll:
Cheers for all the feedback guys ! :)
