rolex 0 Posted March 18, 2007 right, just want some suggestions on what amp an sub to go for please, second hand aint a problem, set up will be audioscape pods with speakers then sub in box with one amp to run it all.(no rear speakers) budgets not alot tho £300 for sub+amp. thanks. Quote Share this post Link to post Share on other sites
Taggart 0 Posted March 18, 2007 Have you already got an amp powering your pods? Quote Share this post Link to post Share on other sites
rolex 0 Posted March 18, 2007 no , wanted an amp to run sub an speckers really, maybe a profile four? Quote Share this post Link to post Share on other sites
slats 0 Posted March 19, 2007 What kind of boot setup do you want? Quote Share this post Link to post Share on other sites
slats 0 Posted March 19, 2007 always a good place to look for second hand http://www.talkaudio.co.uk Quote Share this post Link to post Share on other sites
mrbeige 0 Posted March 19, 2007 Had a listen to my mates Scirocco on Saturday (the red one with the 16v on motorbike carbs that was at Ultimate Dubs) that was running Hertz 6.5" components and 2x 10" subs with the new Audsion LRX 4 channel amp, sounded absolutely awesome! Pi$$ed all over my Focal Utopia components focal sub and old Audison LRX amp!!! If I were after a system now that's what I'd go for! seriously nice sounding system! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 20, 2007 Which Hertz mate? I've seen most of the range as Scape sell them, but I wasn't impressed with them tbh...... great packaging and marketing and very big in Italy where they're from, but the woofers don't have much QTS, and I like my bottom end :-) Quote Share this post Link to post Share on other sites
rolex 0 Posted March 20, 2007 thanks for all the above. mrbeige thats the sort of set up im after,you havnt any pics do you? right im gonna start with the sub/s, whats the difference between sealed aan ported? what are the following like? (sub wise) fli (sp) vibe infinity jl audio jbl audiobahn alpine Quote Share this post Link to post Share on other sites
rolex 0 Posted March 20, 2007 thanks for all the above. mrbeige thats the sort of set up im after,you havnt any pics do you? right im gonna start with the sub/s, whats the difference between sealed, an ported,an base tubes? what are the following like? (sub wise) fli (sp) vibe infinity jl audio jbl audiobahn alpine Quote Share this post Link to post Share on other sites
mrbeige 0 Posted March 21, 2007 Which Hertz mate? I've seen most of the range as Scape sell them, but I wasn't impressed with them tbh...... great packaging and marketing and very big in Italy where they're from, but the woofers don't have much QTS, and I like my bottom end :-) The system is as follows Hertz MLK 165 components £475 Hertz Mille 10 subs £450 Audison LRX4.1 amplifier £700 I thought it sounded really well balanced. Not a huge amount of bass, but well rounded and smooth. Quote Share this post Link to post Share on other sites
mbaker8v 0 Posted March 21, 2007 thanks for all the above. mrbeige thats the sort of set up im after,you havnt any pics do you? right im gonna start with the sub/s, whats the difference between sealed, an ported,an base tubes? what are the following like? (sub wise) fli (sp) vibe infinity jl audio jbl audiobahn alpine Ported tends to give a louder output at the expense of musicality, sealed tends to give a lower peak output but better spread of bass. Sound quality competition cars tend to go sealed, SPL comp cars always use ported. Question is do you want something that sounds good or that goes boom boom that can be heard half a mile away. From the sub makes you listed i would say in order of preference JL Audio, alpine, Infinity, JBL, vibe, fli, audiobahn. All that depends what model from each manufacturer as well... Deoending what you want, what size box you want in your car, how much amp power you have, what sound your after etc will effect which is best for you... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 21, 2007 Not necessarily, I've heard plenty of ported cabinets with a better defined and deeper bass than sealed and with a big frequency range too. These were no boom boom boxes, but properly designed for musicality. Sealed cabinets are easy to design and make. Porting is a lot more complicated and it's usually the badly designed boxes that give porting a bad name, but it's a lot more efficient than sealed. Passive radiating is good too as it relieves the cabinet pressures, but without the blooming of badly designed and loaded ports......it's a very smooth way to port and gives some real depth too if the radiators are large enough. I'm not biased to porting or sealed, I like which ever sounds best and it's always porting to my ears. Quote Share this post Link to post Share on other sites
slats 0 Posted March 22, 2007 do this!! http://www.the-corrado.net/.archive/forum/viewto ... highlight= Tweets - MB Quarts - £35 (ebay) Front speakers - Corals 6.5" - £75 (Talkaudio) Sub - Focal 13" - £100 (Car audio shop end of line model) Sub Box hand made £60-80 (for materials) Front Pods - Audioscape - £125 (shop had an extra set and not many cream cars so I got a bargin!) Amps: Sub amp - PG 1200.1d - £350 (Car audio shop display model but not powed in shop) Component amp - BBG 75.4 (licenced by PG) - £125 (ebay) Cables - £80 - again it was all clearance in local shop. included fuse holders and loads of 4 and 8 guage, phonos and some speaker cable. I am goning to change to a single 5 channel amp soon when funds allow. Really cant stress this enough - CABLES!! Make sure you have a good set of Power and speaker cables. I ran JL Audio Power and chunky speaker wire through the car, I need to (one day) change my phonos but its all in now and I dont want to take it all apart again so when doing the cables do it right the first time!! Oh and it sounds great!! Quote Share this post Link to post Share on other sites
rolex 0 Posted April 11, 2007 looking good slats 8) i need a amp to power the following,once again, just something to do the job not big bucks, all run by alpine cda-9853r mp3wma 50x4amp. front speakers alpine 220w peak power 40w rms 4 ohm 60-20k hz sensitivity 92db 2x10"sub in ported box 400w peak power 200w rms 4 ohm 30-4k hz sensitivity 92db (does that sound any good? :? ) thanks. Quote Share this post Link to post Share on other sites
