GivemeaVR 0 Posted March 23, 2007 My headlights are pointing way too high. Any info on how to adjust would be grateful. Thanks (Its a 1994 VR6) Quote Share this post Link to post Share on other sites
nocrap 0 Posted March 23, 2007 2 'gears' on the back of each, turn to adjust! not the easiest things to get too mind... Quote Share this post Link to post Share on other sites
GivemeaVR 0 Posted March 23, 2007 can this be done with hands? or does it need tools? Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 23, 2007 There's a white plastic knob on the back of each headlight that's designed to be turned by hand. Can be a bit of a squeeze getting to the driver's side one, but not that bad :) Quote Share this post Link to post Share on other sites
GivemeaVR 0 Posted March 23, 2007 i have got a cone filter so hopefully there should be more space. i have some new headlight bulbs to try so cant put them in untill i sort the direction of them out. thanks for the help....probably skinned knuckles tomorrow! Quote Share this post Link to post Share on other sites
nocrap 0 Posted March 24, 2007 Ah new bulbs hey.......probably best to remove the units completely, really is the best and least time consuming way. Work out how much of an adjustment is needed and guesstimate it on your workbench. If you do do this then make sure you replace the screws (2 on top, one down whole in the middle) with some stainless, will save you literally hours of grief further down the line! Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 24, 2007 yup. plastic knob thing on the back of each headlight. If you can do it in the dark with the lights on against a wall with another car next to it parked at the same distance to the wall to align. worked for me Quote Share this post Link to post Share on other sites
