Roger Blassberg 0 Posted April 30, 2007 Is it as simple as undoing the four bolts, (two each side) from under the boot floor, and pulling the bumper back from the car, or are there any other fixings to the sides? Best wishes RB Quote Share this post Link to post Share on other sites
g60greeny 0 Posted April 30, 2007 as easy as that mate Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 30, 2007 Yip - if it's not been off before then it should be fairly easy as the bolts won't be too tight and will still have the factory coating on them... If it's been off and stuck back on by a body shop then you may need to steel some scaffold! :lol: Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted April 30, 2007 Bolts all start to turn, I just have not yet fully undone them. So it sounds like it might be one of those very rare things, "An Easy Job". Thanks all Best wishes RB Quote Share this post Link to post Share on other sites
fla 9 Posted April 30, 2007 Roger? Just be careful when you remove the bumper as it will drop towards you. It helps to have some old carpet or something similar just in case the turn catches you out. Its not heavy, just awkward. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted April 30, 2007 Thanks for the tip - I'll put a painter's dust sheet down under it. Best wishes RB Quote Share this post Link to post Share on other sites
