G60RMM 0 Posted July 3, 2007 Hi there, I've just bought a Wietec Ultra GT suspension kit (with 40mm drop), from G-Werks and will be having it fitted soon; so am looking for the above information. I've had a search and haven't been to find a definitive answer. Though not being hugely clued up on suspension geometry, I probably wouldn't know it if I did find it! Does anyone know what the ideal settings should be? I've also tried here: viewtopic.php?f=23&t=57304&p=677601&hilit=#p677601 but can't get the PDF to open :( Many thanks Roy Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 3, 2007 You can't [easily] change the caster on Corrados. Camber is usually around the -0.8 to -1 mark. Quote Share this post Link to post Share on other sites
Crasher 4 Posted July 3, 2007 Camber is 35 minuets negative and the tracking parallel i.e. 0 Quote Share this post Link to post Share on other sites
G60RMM 0 Posted July 3, 2007 Excellent. Thanks for the replies, hopefully this should be enough for the guy fitting the suspension to go on. :D Cheers Roy Quote Share this post Link to post Share on other sites
