quicky1980 0 Posted July 4, 2007 I took the fusebox out of my vr and putting a new one back in, only problem is im not sure which plugs go into which soccket. Some obviousely can only go into one socket but a few seem to have same shaped plugs so im worried ill plug it all in wrong. is the an easy way of working it all out? thanks Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted July 4, 2007 I'm pretty sure that none of them are the same mate. Quote Share this post Link to post Share on other sites
B5VWC 0 Posted July 5, 2007 here you go check the fusebox part no. http://www.bentleypublishers.com/tech/v ... 9-1997.htm 30b - red- fuse/relay panel pin 30, park/neutral relay pin 2 and alarm system control unit & indicator light A1 1 - yel/blk- left Headlight pin 56b (dipped beam) (fuse #1) 2 - blk/wht- left front indicator & side repeater and dash plug 22 (left indicator light) 4 - gry/blk- left parking light (fuse #8) 5 - red - radiator fan thermo switch pin 3 and/or run-on control unit pin 4/30 6 - wht/blk- left Headlight pin 56a (full beam) & spotlight (fuse #11) \- red - radiator cooling fan run-on control unit (fuse #19) 7 - blk/yel- high & low horns (fuse #13) \- blk - rad cooling fan run-on control unit (fuse #13) 8 - brn/blk- high & low horns (horn relay) A2 1 - blu - alternator pin D+ 2 - grey/red- right parking light (fuse #7) 3 - yel - right Headlight dipped beam pin 56b (fuse #2) 4 - blk/grn- right front indicator & side repeater and dash plug 24 (right indicator light) 5 - brn - earth (location 120) 7 - wht - right Headlight 56a (full beam) & spotlight (fuse #12) 8 - wht/yel- fog lights B 4 - brn - fuse/relay panel pin C/3 5 - red - fuse/relay panel pin Y/2 C 1 - blu/brn- brake fluid low level switch pin 1 or ABS brake warning switch 2 - grn/red- washer pump pin 1 3 - brn - fuse/relay panel pin B/4 7 - brn/yel- washer pump pin 2 8 - blu/yel- coolant level sensor pin 1 D 5 - blk/yel- sunroof switch 7 - blk/yel- ABS pump relay pin 4 8 - blk - alarm module pin 4, A/T switch pin 5, A/T control module pin 19 and shift lock solonoid 9 - blk/blu- electric window control unit, left & right front window switches pin 4 (in left & right door), electric seats and sunroof control module pin 6 \- blk/wht- drivers seat heater control unit & switch and passenger seat heater control unit 11- blu/red- transmission control module pin 38 and heated washer jets \- blk - cruise control switch pin 4 \- blk/yel- electric mirror switch pin 5 12- gry/blu- A/T console light and seat heating switch light E 2 - blk - heated washer jets 3 - blk/red- brake light switch pin 1, A/T control module pin 26, clutch & brake vacuum vent valves (cruise control) 4 - red/yel- brake light switch pin 2 5 - brn - cylinder head & PCV heating element F 1 - red/blk- stater motor pin 50 \- red - park/neutral position relay pin 6 and motronic engine control module pin 7 \- red/grn- alarm module pin 5 3 - blu - alternator pin D+ 6 - blk - reverse light switch pin 2 (M/T) or park/neutral relay pin 5 (A/T) 7 - blk/blu- reverse light switch pin 1 (M/T) or park/neutral relay pin 4 (A/T) 8 - grn/red- A/T multi-function switch pin 5 9 - grn/blk- A/T control module pin 27 G1 1 - brn - cig lighter pin 1 2 - brn/yel- outside air temperature sensor pin 1 3 - yel/blu- motronic engine control module pin 6 4 - blk - motronic engine control module pin 38, ignition coil pin 3 and speed sensor pin 1 5 - brn/wht- earth (cylinder head?) 6 - brn - speed sensor pin 3 7 - blk/brn- motronic engine control module pin 9 8 - red/yel- heated O2 sensor pin 2 and fuel pump after-run module 10- red/blu- injectors, hall sender pin 3, evap & EGR frequency valves, MAF sensor pin 5, O2 sensor control module pin 6 and motronic engine control module pin 23 11- wht/blu- vehicle speed sensor pin 2 12- grn/red- motronic engine control module pin 22 G2 1 - grn/blk- oil temperature sensor 2 - wht/red- outside air temperature sensor pin 2 3 - blu/wht- coolant temp sensor pin 2 & radiator fan run-on thermoswitch pin 2 4 - blk/yel- PCV heating element 10- yel - oil pressure switch 1.8 bar 11- blue/blk- oil pressure sender 0.3 bar H1 1 - red/blk- ignition switch pin 50 2 - red - ignition switch pin 30 3 - blk/yel- ignition switch pin X 4 - blk - ignition switch pin 15 5 - blk/blu- indicator stalk hazard button pin 4 & dual horns 6 - brn - wiper stalk 3pin plug pin 3 7 - brn/red- ignition switch pin S radio pin 4 8 - grn/red- wiper stalk 3pin plug pin 2 9 - grn/wht- wiper stalk 5pin plug pin 1 H2 1 - brn/blu- indicator stalk contact pin 2 - grn/red- indicator stalk pin 6 3 - grn/blk- indicator stalk pin 4 4 - blk/grn- indicator stalk pin 7 5 - grn - indicator stalk pin 5 6 - blk/wht- indicator stalk pin 3 8 - blk/wht/grn- indicator stalk pin 2 J 1 - wht - indicator stalk pin 4 2 - wht/blk- indicator stalk pin 3 3 - yel - indicator stalk pin 2 4 - red/yel- indicator stalk pin 5 5 - grn - wiper stalk 5pin plug pin 3 6 - brn/blk- wiper stalk 5pin plug pin 5 7 - blk/gry- wiper stalk 5pin plug pin 2 8 - wht/yel- indicator stalk pin 1 (hazard button) 9 - grn/blk- wiper stalk 5pin plug pin 4 10- grn/yel- wiper stalk 5pin plug pin 1 K 1 - blk/wht- left rear indicator 2 - gry/red- right rear light 3 - gry/blk- left rear light 4 - blk/red- left brake light 5 - gry/grn- number plate lights 6 - blk/yel- rear wiper motor pin 53A 7 - blk/grn- right rear indicator 8 - blk - left reverse light pin 0 9 - grn/blk- rear wiper motor pin 53 11- brn - spoiler switch pin 4 & control module pin 6 12- wht - rear window heater element L 1 - brn - handbrake switch 5 - red - boot light and ABS diagnostic connector pin T2X/2 6 - brn/blk-gry- handbrake switch 7 - red - interior light pin 3, sunroof control module pin 5 and vanity mirror light switch M 1 - brn - fuel pump pin 31 2 - red/yel- fuel pump pin P 3 - vio/blk- fuel level sensor pin G 5 - blk/blu- interior light pin 1, spoiler control module pin 2, sunroof switch pin 3 and A/T program switch pin 1 (light) 6 - brn/blu- fuel level sensor pin 31 N 1 - red/yel- fresh air motor & resistor 2 - red/wht- radiator fan control module pin 3, thermal switch pin 2 and radiator fan pin 3 3 - red/wht- battery 4 - red/yel- A/C pres switch pin 4 5 - blu/red- motronic engine control module pin 39, A/C press switch pin 2 & clutch relay 6 - yel/red- fresh air switch pin 4 P 1 - wht/yel- fog light switch pin 83a 2 - blk/yel- rear screen heater switch pin + 3 - wht/grn- rear screen heater switch pin 86 and heated mirror glass 4 - gry/yel- fog light switch pin 83 5 - brn - rear screen heater switch pin 31 6 - gry/wht- fog light switch pin 83b 7 - gry/blu- rear screen heater switch pin 58b 8 - brn/wht- fog light switch pin 31 9 - gry - fog light switch 58b Q 1 - brn - cig lighter pin 1 2 - blk/yel- fresh air blower switch pin 2, radiator fan control module pin 4, 3rd speed fan & A/C switch pin 3 and ambient temp switch 3 - red/wht- radio main plug pin 7 (live feed) 4 - blk/yel- voltmeter & oil pressure gauge & glovebox light 5 - red/gry- cig lighter pin 2 6 - gry/blu- radio main plug pin 6, cassette storage light, cig lighter pin 3 (light), oil pressure & voltmeter gauge lights and fresh air control light R 2 - gry/blk- fuse/relay panel pin R/7 & R/6 3 - gry - headlight switch pin 58e (dash light dimmer slider) 4 - gry/blu- headlight switch pin 58b (dash light dimmer slider) 5 - red - headlight switch pin 30 6 - gry/red- fuse/relay panel pin R/2 & R/7 7 - gry/grn- fuse/relay panel pin R/2 & R/6 and headlight switch pin 58 8 - brn - headlight switch pin 31 9 - wht/blk- headlight switch pin 56 10- blk/yel- headlight switch pin X S 1 - blk/gry- windscreen wiper motor pin 53a 2 - grn/blk- windscreen wiper motor pin 53 3 - brn - windscreen wiper motor pin 31 4 - grn - windscreen wiper motor pin 53e 5 - grn/yel- windscreen wiper motor pin 53b U1 1 - blk/wht- dash plug pin 17 (oil temp sensor) 2 - vio - dash plug pin 19 (outside temp sensor) 3 - yel - dash plug pin 8 (oil pressure control unit - feed from 1.8 bar) 4 - blk - dash plug pin 13 (fuse #16, power feed?) 5 - red/wht- Dash plug pin 9 (oil pressure control unit - feed from 0.3 bar) 6 - grn - dash plug pin 10 (rev counter) 7 - blu/wht- dash plug pin 1 (outside temp sensor) 10- brn - dash plug pin 3 (ground) 12- blu - dash plug pin 21 (fuel gauge) 14- gry - dash plug pin 12 (dash bulbs) U2 2 - vio - dash plug pin 7 (vehicle speed output) 3 - yel - dash plug pin 18 (seat belt warning) 4 - blk - dash plug pin 15 (MFA switch pin 2) 5 - red/wht- dash plug pin 2 (coolant level warning light) 6 - grn - dash plug pin 24 (direction indicator light) 7 - blu/wht- dash plug pin 25 (high beam warning light) 8 - grn/wht- dash plug pin 6 (MFA switch pin 3) 9 - yel/red- dash plug pin 23 (coolant temperature gauge) 11- red - dash plug pin 11 (fuse #21, power feed?) 12- blu - dash plug pin 16 (battery warning light) 13- brn/wht- dash plug pin 5 (earth & MFA switch pin 1) 14- gry - dash plug pin 4 (MFA switch pin 4) V 1 - red/wht- wiper stalk pin 2 mode button 2 - brn/wht- wiper stalk pin 1 memory reset switch pin 1 3 - blu/yel- wiper stalk pin 3 memory select slider 4 - yel/red- wiper stalk pin 4 memory reset switch pin 4 W 1 - blu/wht- motronic engine control module pin 65, spoiler control unit and radio \- wht - cruise control unit pin 5 2 - gry/blk- ABS relay pin 3, ABS diagnostic connector and ABS control module pin 27 4 - blk/red- ABS control unit pin 12 5 - brn/wht- ABS hydralic unit switch pin 2 6 - wht/blu- ABS brake fluid low level switch pin 1 and ABS control module pin 9 X 1 - red/blk- warning module pin 1 (solid state) & starter interlock/reverse light relay 2 - brn - warning module pin 2 (solid state) 3 - gry/grn- warning module pin 3 (brake/handbrake warning light) 4 - blk - warning module pin 4 (brake/handbrake warning light) 5 - wht/blu- warning module pin 5 7 - brn/wht- warning module pin 7 8 - yel/red- warning module pin 8 (ABS warning light) Y 1 - red/yel- motronic engine control module pin 54 & electric seats 2 - red - fuse/relay panel pin B/5, electric window relay pin 30, central locking pump & door switches pin 1 and sunroof control module pin 7 3 - red - battery positive terminal Z1- Z2- brn - battery negative Quote Share this post Link to post Share on other sites
tonedef 10 Posted July 5, 2007 You gotta say that's a fairly comprehensive reply :shock: :shock: :shock: Quote Share this post Link to post Share on other sites
quicky1980 0 Posted July 5, 2007 cheers guys will go out and plug it all in when the weather gets better Quote Share this post Link to post Share on other sites
quicky1980 0 Posted July 5, 2007 ok, plugged in all the plugs into the back. plugs can only go in correct sockets. some sockets havent got plugs in them, is this normal also i have loads of wires hanging from the jungle of loom near the fusebox. they look like they are supposed to connect to some things but god knows where but tried to see if car would run,turned the key and noticed no fuel pump noise, turned car over but no start. what am i missing? must point out that this is a converted 2.0 16v to a vr6 Quote Share this post Link to post Share on other sites
