cardboard 0 Posted July 25, 2007 when attempting to turn the wheel there is a screeching and the steering wheel sort of jerks round i beleive this is the powersteering pump is this correct? are they easy to fit and how much are they? Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 26, 2007 quite a few threads on this already, use the search. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted July 26, 2007 I've got a spare G60 power steering pump - what have you got? Quote Share this post Link to post Share on other sites
cardboard 0 Posted July 26, 2007 its for the other 1.8 16v Quote Share this post Link to post Share on other sites
Toad 0 Posted July 26, 2007 its for the other 1.8 16v I've got a 1.8 16v pump spare, taken off the car, hot to trot... but I'd be tempted to check the fluid, and possibly replace it before buying a pump. Quote Share this post Link to post Share on other sites
n3p 3 Posted July 26, 2007 bought mine for £105 from a local auto shop - Is quite easy to fit if not really fiddly. Before making a commitment to buying a new pump, I reckon you should change the fluid, and give it a good bleeding - helped mine alot before it was time to change, but not quite enough - might be different in your case tho :)Also check the belt tension while you're down there! Quote Share this post Link to post Share on other sites
