STORM 2 0 Posted August 25, 2007 Whats an implausible signal? As opposed to NO signal? Is the Vehicle Speed Sensor(gearbox ) the same thing as the Engine speed sensor ? Full Error Code from VAG-COM :: 00281 VSS (G68) 27-00 - IMPLAUSIBLE SIGNAL There are no problems with engine running - only problem is the spoiler not raising at speed - could it be the wiring from the VSS to the main loom connector (the twisty one next to the coolant pump?) Quote Share this post Link to post Share on other sites
Toad 0 Posted August 25, 2007 I think it means that the sensor is playing up. Quote Share this post Link to post Share on other sites
Crasher 4 Posted August 29, 2007 So this is a VR6 auto. The sensor is for road speed and is located in the top of the gearbox. Quote Share this post Link to post Share on other sites
