ValRado 0 Posted September 4, 2007 Hell, the battery is loose on my 16v, I cannot see how to secure it so could someone post a picture of theirs secured please I'll be able to work it out from that! Thanks! Paul Quote Share this post Link to post Share on other sites
jonny-5 0 Posted September 4, 2007 I haven't got a photo to hand but there should be a small clamp at the front of the battery tray that is held down by a 13mm (i think) bolt, the opposite side of the battery is sort of wedged under a non removalble ledge. Hope this helps. P.S. Loving the avatar, fonejacker's quality - although it doesn't get the recognition it deserves. Quote Share this post Link to post Share on other sites
Yandards 0 Posted September 4, 2007 Hello, You should need a small strip of plastic that clips onto the bottom front of the battery to ensure a good fit to the car. The battery clamp is located at the front centre of the battery area and is held in by a single bolt, if you just have a rusty hole, oh er!, then you will need a new clamp. The new one from VW comes with an extra bit on it, this needs to be cut off. Quote Share this post Link to post Share on other sites
corrado vr6 0 Posted September 4, 2007 heres a piccie hope this helps Quote Share this post Link to post Share on other sites
ValRado 0 Posted September 5, 2007 Cheers guys, I'll have a better look at it tonight! :) Yes fonejackers mint! Starts again on friday! :D Quote Share this post Link to post Share on other sites
