Jim Bowen 1 Posted September 30, 2007 i only got car back on road yesterday after sorting the steering/suspension and today whilst driving loads of steam starting pouring out of car have found a big split in the pipe shown i guess thats the cause and water pouring onto exhaust was the steam. am thinking of ungrading all the water hoses now, but first need to get this pipe asap, should i go to VW or elsewhere? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted September 30, 2007 I feel for you mate,that's happened to my corrado loads of times (2.0 valver.T.16v),i don't own a Vr6 version but i do have quite a few spares for the Vr,including that hose.Only problem is that i'm in Rome so getting the hose posted would take awhile... If you don't have any luck locating the hose let me know and i'll send you mine. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 30, 2007 thanks and thanks for the offer, but i think i'll be off to the dealers tomorrow after a quick search it seems thats the only quick option, but think i'm going to look into samco's Quote Share this post Link to post Share on other sites
dr_mat 0 Posted September 30, 2007 Yes, dealer part only. Apparently it's come down in price slightly too, only £35 now .. ! That's always the first pipe to go. It usually splits down by the cylinder head, caused by a combination of old age and flex caused by sloppy engine mounts. When mine went the guy managed to cut an inch off the end of the hose and re-attach it so I could continue my journey, I guess your recovery guy either didn't bother or your hose was split in a different place .. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 30, 2007 he said he could fix it but i said may as well jut get it home, i didn't want to break down again etc prehaps jacking the engine etc up to fit track rods has disturbed it enough to break Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 30, 2007 the split all the way from the head to the bit where the t-joint comes out, so about 3" long Quote Share this post Link to post Share on other sites
tonedef 10 Posted September 30, 2007 If it's on back order or something like that I've got one laying about in the garage at home, there was nothing wrong with it only I had to use a different one with a temp sensor in for the climatronic. Of course it's probably the original one so 12 years old and I'd have to get my wife to dig it out to post it but the offer's there. Let me know if you're stuck :D Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 30, 2007 nice one, i'll get back to you if needed. hopefully i'll know by tomorrow if they can get one Quote Share this post Link to post Share on other sites
A1 VR6 0 Posted September 30, 2007 There was one on e-bay a couple of days ago with a low start price - trawl through the 8 or 9 pages might still be there :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 1, 2007 quick question to fix this, do i just replace the pipe, fill up water in expansion tank, or do i need to do anything to get any air out of system etc? Quote Share this post Link to post Share on other sites
A1 VR6 0 Posted October 1, 2007 Just set the heater control to hot to let water flow into the heater matrix while filling and leave the cap off the expansion bottle while running the engine to warm it up. Always works for me. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 2, 2007 so fit hose, fill with water, leave cap off, start engine, top up as needed, refit cap? i plan to do this tonight as got my hose now Quote Share this post Link to post Share on other sites
A1 VR6 0 Posted October 2, 2007 so fit hose, fill with water, leave cap off, start engine, top up as needed, refit cap? i plan to do this tonight as got my hose now Bit late posting, but yes and If you've done the job already, should be a good un. I assume you have as you haven't posted again with a problem :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 2, 2007 i got home from work and popped into a local garage and asked them they said fit hose, top water up, replace cap, start engine, heaters on, run till hot, switch off, cool down and refill if needed finished job, everything seems fine to me, the rear of engine sounds a bit hissy? but may of always done that, its a thing that looks like a black shampoo bottle lid here is the culprit is this a common thing to happen? am a bit concerned that something else led to the pipe bursting? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 2, 2007 Hmmm - probably just age but worrth checking the rest of the system is working as it should - a failing aux water pump could cause this! Quote Share this post Link to post Share on other sites
A1 VR6 0 Posted October 2, 2007 is this a common thing to happen? am a bit concerned that something else led to the pipe bursting? When the hoses get old yes so shouldn't be too concerned that something else caused it Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 2, 2007 Hmmm - probably just age but worrth checking the rest of the system is working as it should - a failing aux water pump could cause this! is the water pump on the left hand side of engine, where the belts are? that did sound a little noisy, slight squeak and a grind Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 2, 2007 i just worry :lol: i don't want to break down too often and would hate for any damage to be done to engine for a silly reason like a hose/pump Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 2, 2007 Aux water pump is an electric pump behind the block, on the passenger side of the engine. The main water pump is on the driver's side at the bottom of the block, driven by the aux belt. I would suspect that the pipe died due to old age myself. No need to turn the heater to "hot" by the way, there's always flow through the heater matrix on these cars, it's not like the old ones where the heater control stops/starts the water flow.. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 3, 2007 thanks, i'm just going to accept it was the hose at fault and nothing else, haven't been any other problems to suggest otherwise Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted October 3, 2007 Yep the same hose gave up on mine last month, got one from the stealers £35 as mentioned :? until my samco's arrive :) Quote Share this post Link to post Share on other sites
