dgarwood07
Door strips!!
Remove looks miles better without and they fall off eventually anyway!
just look 1 off but it had been stuck on so gott find away 2 remove all the glue or watever it is!!! :?
i had to remove mine once just heat them up with a hair dryer or if yr daring like i was i used a heat gun which warms the glue and u just gradually pull them off, i used some pre-paint which i had around at the time which sorted out the glue residue, got that from frost.co.uk, deffo looks better without, but as everyone has said in the past beware in car parks!! :lol:
HA HA HA HA HAHA Im so glad im not the only person to have removed them and found glue. I used superglue remover which also took off a layer of paint. So im getting the door panel resprayed on thursday at last.
You could try boiling water and a plastic knife. I got alot of the superglue off like that. Good luck with it!!!
