Jim Bowen 1 Posted October 18, 2007 i'm always telling folk not to lean or put downward weight on my doors when they open but they don't listen. lately my doors seem to catch the sill very slightly when shutting them, is only a tiny amount, i grabbed pass door and pulled it up gently which has stopped that side from rubbing. but the drivers door seems loose, its knocks if you lift it up and down is this something just needed adjusting? Quote Share this post Link to post Share on other sites
fla 9 Posted October 18, 2007 Cant really adjust it pal, but the C doors are prety damn heavy anyway. What i did was loosen the top bolt and slide an n-shaped shim between the hainge and the frame to pull the door up to normal. You may need to replace the door hinge pins though. If so, make sure you oil and grease tehm well. Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 18, 2007 I've had some shims made up at work. Let me know if you want to try some. They worked a treat for me but I guess it depends on how much the door has dropped. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 19, 2007 thanks guys, i'll investigate whats up a bit more this weekend spose its a great excuse to go for lambo doors :lol: not....... Quote Share this post Link to post Share on other sites
