greegs
coolant leak
hi there, only had my '93 vr6 for few weeks but have a slight coolant leak. seems to be coming from lower radiator hose, but end coming off engine block, hard to tell though but that's where most of water appears to be leaking from. only seems to leak after driving hard. could worn engine mount cause leak due to excessive movement? have to top up water every few days so not too major just annoying. have been told all sorts including; crap hose clip? worn o-rings? . apart from this cannot fault car, so fast! would appreciate any help.
only stumbled across site few days ago-well impressed.
:) if it is the plastic flange on the block then you need to remove it and check the flange for cracks and see if the seal is worn. Hope that is of help
:) is this plastic flange easy enough to remove? take it you mean seal on engine block? will i need to drain coolant to remove flange? are these parts expensive to replace? is this fault common? sorry about all the questions!!
JESUS :shock:
I aint even enlarged it, but DAMN... there is a lot of arrows......
Yeah well it is national VR6 coolant leak week :lol:
Most of the arrows are on the matrix, which can rupture anywhere, hence the random scattering of them!
Kev
