davidwort 0 Posted May 11, 2010 Thread resurrection time, for those who don't wan't the bling foil coated effect, how about this: http://www.soundproofing-direct.com/pc/ ... -12p57.htm still can't find the OEM waffle type foam anywhere Quote Share this post Link to post Share on other sites
Kempy 0 Posted May 11, 2010 http://www.corrado-teile.de/shop/produc ... o-VR6.html Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 11, 2010 http://www.corrado-teile.de/shop/product_info.php/info/p2386_Hood-Sound-Deadening-Foam---Corrado-VR6.html late model bonnet though, which is also still available from VW if you have an early bonnet there's no OEM foam available. Quote Share this post Link to post Share on other sites
Jonny777 0 Posted May 11, 2010 http://www.corrado-teile.de/shop/product_info.php/info/p2386_Hood-Sound-Deadening-Foam---Corrado-VR6.html late model bonnet though, which is also still available from VW if you have an early bonnet there's no OEM foam available. You get any idea how much it is from VW still matey? Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted May 11, 2010 Are you trying some of the foam david ? i must admit i would rather have it black but....nearly three years on and the noisekiller still looks brand new on mine :D Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 11, 2010 Are you trying some of the foam david ? i must admit i would rather have it black but....nearly three years on and the noisekiller still looks brand new on mine :D Will be painting bonnet soon hopefully and my old foam is crumbling badly now, need something in there, but not sure what. Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 11, 2010 That noisekiller being foil lined looks like it would be easy to clean... The OEM stuff soaks up oil and grit like s**t on a stick. You could always lacquer the foil a dif colour if you didn't like the shiny surface Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 11, 2010 That noisekiller being foil lined looks like it would be easy to clean... The OEM stuff soaks up oil and grit like s**t on a stick. You could always lacquer the foil a dif colour if you didn't like the shiny surface And at £40... looks like a bargain. I think i might ask if hes still doing the discount :D Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 11, 2010 That noisekiller being foil lined looks like it would be easy to clean... The OEM stuff soaks up oil and grit like s**t on a stick... if you keep your oil filler cap on, it won't spray on the inside of the bonnet :wink: Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 11, 2010 That noisekiller being foil lined looks like it would be easy to clean... The OEM stuff soaks up oil and grit like s**t on a stick... if you keep your oil filler cap on, it won't spray on the inside of the bonnet :wink: Thanks Captain! but... should I leave the cylinder head bolts off in that case? i like to let my engine breath you know.... :tongue: don't you find that the oem stuff does accumulate dirt though? after 20years on the car and countless dirty roads driven mine are quite mingging Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 11, 2010 mine are quite mingging no puns please... :roll: Quote Share this post Link to post Share on other sites
soother 0 Posted May 11, 2010 I got mine from VW £70 ish last year for the late bonnet Not that I have my Corrado any more Iv gone to the dark side Audi S3. Quote Share this post Link to post Share on other sites
fla 9 Posted May 11, 2010 tbh a lot of the dynamaty-type of stuff wont do much, just stop panel vibration. the acoustic foams are the ones that stop airborne noise, which is whats needed. well, a combination of both. Quote Share this post Link to post Share on other sites
