easypops 8 Posted November 4, 2007 hi all, been having trouble with the cooling on the car for what seems ages now craigowl posted this pic of his fan control module his is a VR6 , mine is a 2.0 16v i DONT have this anywhere obvious in the engine bay but i'm guessing it must be somewhere any ideas? thanks in advance Quote Share this post Link to post Share on other sites
Yandards 0 Posted November 4, 2007 Nope. IIRC all other models have the fan control run on system as part of the fuse board via a relay setup. Quote Share this post Link to post Share on other sites
easypops 8 Posted November 4, 2007 Nope. IIRC all other models have the fan control run on system as part of the fuse board via a relay setup. that what i thought...according to autodata its number 15 relay (pic below) but where that is meant to be is a fuse which seems to be for the electric windows totally lost now :( Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 4, 2007 Whats the exact problem with your cooling? Is the fan not working or just slow? Could be loads of things, give us a bit more info :-) Quote Share this post Link to post Share on other sites
easypops 8 Posted November 4, 2007 there is a wee bit more info here :lol: viewtopic.php?f=1&t=62527 Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 4, 2007 Ahh :oops: sorry and have to admit I didnt read through the whole thing but I did notice that the problem got worse on replacing the Thermostat? If so that makes sence as I replaced mine with a new one from VW and on the drive home I got 130 degrees on the oil :shock: Ended up putting the old one back in as there was nothing wrong with it apart from age. Quote Share this post Link to post Share on other sites
easypops 8 Posted November 4, 2007 well i have not yet replaced the thermostat....but i am sick of not having it running so its off to the garage in the morning for them to fit new thermostat, water pump , coolant temp sensor ....to go with the new thermo fan switch already in place fingers crossed it will be ok after that :lol: but it is a corrado......so we'll wait and see anything else i should replace while i'm at it ? Quote Share this post Link to post Share on other sites
