Rob_G60
idle problem
Hi all
have a bit of a problem with my G60, the other week a snapped a bolt on the front engine mount which knocked my coil pack and the car cut out so we plugged it back in, but now the car revs funny, when i turn the car on it goes up to 2000rpm then dies down to about 1000 but goes up and down, i notice the coil pack has a crack in it would that cause this
If not what could it be
any help would be great
cheers
Rob
Hi all
cheers
Rob
Er coil pack?
G60s dont have a coil pack.
Did you hit the ignition coil on the bulkhead?
If so you will probably need a new ignition coil as this will effect the spark quality if it is damaged.
thats the one (orange one)
yeah when the engine mount snapped it got crushed and all plugs came off it to,
