Gypsydal
headlights
I can see there are similar links on here but not exactly the same, can anyone please help with a problem I have. When running with normal beam all is fine, but when I switch to main beam, the entire nearside lights go out. I have only recently bought the car, so know very little about it. The headlight colour is daylight, so I think someone has changed the bulbs. Any help gratefully appreciated cos I cant see when going round left handers!!!!!!!!!
Sometimes the filaments in the bulbs can break and touch where they shouldn't causing this exact problem.
Maybe worth just double checking the bulbs...there are other reasons it can happen,but bulbs is the easiest to check.
Neil.
Sounds like it might be something to do with the wireing, have you had a look at it? it maybe a 'uprated loom' that someone's bought on Ebay which vary in quality?
