dinkus 10 Posted February 15, 2008 So I spent a couple of hours this morning soldering ISO plugs back onto the original car loom that some thieving pikey shite had lovingly hacked out at some stage. In hindsight, crimps would have been nicer but ho hum. Anyway, I have all the wires connected up apart from 1. The ISO plug I was given has a black wire coming out of the power-related plug, but I have no corresponding part of the car loom to wire it in to. If I plug the head unit in, it only turns on when the ignition is in acc position - if I turn it round to full-on the head unit turns back off again. From what I gather and indeed from what I've found on here - this black wire should be 12v switched ignition live... but I can't find any loose wires anywhere in the dash. Does anybody know where this wire usually comes from as it can't have just disappeared? Alternatively, can anyone suggest a good place to take a splice from for it? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 15, 2008 don't you join two wires together from the headunit and then connect to one wires from the car, i remember doing this once Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 15, 2008 Yeah, there's the whole red/yellow wire swaparoo, but that's on the bit of loom that goes from the car's ISO plugs to the head unit. At the moment I'm just repairing the loom in the car - so ignore anything that goes past the ISO plug to the head unit. Essentially, I've got 2 bits of loom. The plug-side has a black wire on it, the car-side doesn't and I dunno what to find in the car to connect to it. Quote Share this post Link to post Share on other sites
Walesy 0 Posted February 15, 2008 black - ISO - yellow - green Blue - yellow - ISO - HU - brown brown - black - blue - ISO - HU HTH Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 15, 2008 black - ISO - yellow - green Blue - yellow - ISO - HU - brown brown - black - blue - ISO - HU HTH Er you whatnow? :lol: Quote Share this post Link to post Share on other sites
Walesy 0 Posted February 15, 2008 Dunno , I just see your threads as an excuse to be silly on Friday afternoons, sorry :oops: - i'll go back under my rock again now... Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 15, 2008 Well I did wonder when you'd learned about car electrics :lol: Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted February 15, 2008 Dom, can you sling up a photo? My stereo's back to "temp" install while i Track out the intermittant wiring to the front speakers, think it's in the HU-ISO wiring.. grrr... I'll have a look over the weekend for you. But as it's Friday and I had to guess, a pink wire? :lol: Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 15, 2008 Thusly. The black wire comes out of/goes into pin 5 on the plug. Quote Share this post Link to post Share on other sites
Toad 0 Posted February 15, 2008 Those plugs look sexy.... Quite surprised they don't just connect up correctly given thier origin. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted February 15, 2008 Pretty sure that's for the amplifier in the antenna, dude. Quote Share this post Link to post Share on other sites
Philuk 0 Posted February 15, 2008 blue is remote wire for amps, black is earth. red - perma/switched live yellow - perma/switched live black - earth orange - illumination blue - remote *edit* what looks like pink will prolly be mute for a mobile phone doofer :) is that all thats on it? Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 16, 2008 This is the best description I've found so far: If I remember right this is the iso plug colours: Battery +12 volt: Yellow or Red Illumination: Orange Ignition +12 volt: Red Electric Aerial: Blue grey is front right green is front left white is back right purple is back left Phone Mute: Purple And this is the VOLKSWAGEN colours: P o w e r Memory (+12v Constant) Red Ignition (+12v Switched) Black (not available in older models) Ground (-) Brown Illumination Gray or Gray/Blue Dimmer (none) Power Antenna White S p e a k e r s Right Front (+) Red Right Front (-) Brown/White Left Front (+) Blue Left Front (-) Brown/Blue Right Rear (+) Red/Green Right Rear (-) Brown/Black Left Rear (+) Blue/Green Left Rear (-) Brown/Red styles/prosilver/imageset/icon_post_target.gif Which would imply that it's ignition live. I'd also go with that description as the head unit comes on in ACC position, but goes off again when the igintion is full-on. Toadypoos - would you be able to look on the car the plugs came out of to see if you can trace the corresponding black wire and find out where it comes from? Quote Share this post Link to post Share on other sites
VR6 0 Posted February 16, 2008 Whatever you do, don't cut the green wire. Quote Share this post Link to post Share on other sites
andygal 0 Posted February 17, 2008 is the black wire next to the earth (brown in ur pic) if so, its the illumination wire (usually orange). You dont need to bother with this...its there so that you can hook it up so when you adjust the brightness of the dash, the cd player brightness changes as well Andy Quote Share this post Link to post Share on other sites
Toad 0 Posted February 17, 2008 b0llocks, forgot to check the cable arrangements again in the daytime, sorry dude :( Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 17, 2008 is the black wire next to the earth (brown in ur pic) if so, its the illumination wire (usually orange). You dont need to bother with this...its there so that you can hook it up so when you adjust the brightness of the dash, the cd player brightness changes as well Andy Isn't that the grey/blue wire from the list above (which may or may not be definitive)? I think it must be something to do with ignition live because the stereo turns off when you turn the igntion on... b0llocks, forgot to check the cable arrangements again in the daytime, sorry dude :( No spooning for you tonight. Quote Share this post Link to post Share on other sites
andygal 0 Posted February 17, 2008 if the black wire on your new loom is next to your earth wire then it is your illumination wire. Lives are the one below the earth and the 3rd one along in the same row as the earth Andy Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 17, 2008 I'm gonna have to go and double check all this tomorrow. If it is the illumination wire, then it sounds like I've got something else fubar :( Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 23, 2008 So firstly - the black wire (in this case) is for illumination switching. Why/what and where is anybody's guess. But it can wait for now. However, I did manage to get the multimeter out and test the wires I've got... Red: 12v+ constant Brown: Ground Brown/red: Acc position only (i.e. off when the ignition is fully off and off when the ignition is fully on) Blue/white: Ignition fully-on only Blue/grey: Nothing ever, but looking at the wiring diagrams for the stereo, it looks like it's probably for the aerial amp, so actually gets fed by the head unit. Can any body explain why there is 1 wire for ACC and 1 for Ignition? Shirley that should all be on one wire? Is it going to do any damage wiring the two together (i.e. is the back-current going to cause issues further back in the loom?) At the moment, I seem to have the wire that is ACC-only live is in the pin that should have ignition live only and the pin that is actually ign-live only goes into a hole that the head unit has no use for. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted February 23, 2008 dinkus, I'm 99% sure that the blue grey one is speed pulse input to the standard stereo. I wired that up to the aerial outputon mine and the spoiler stopped working, as there is no protection circuitry in the clocks for that I/O line, it blew a transistor on the board. There as a spoiler fixing thread that I started ages and ages ago somewhere.... Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 23, 2008 Oh flange. Well I didn't poke 12v up the blue/grey one, but I did poke 12v up the blue/white one. I hope I haven't popped the speed controller :( Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted February 25, 2008 Can any body explain why there is 1 wire for ACC and 1 for Ignition? Shirley that should all be on one wire? Is it going to do any damage wiring the two together (i.e. is the back-current going to cause issues further back in the loom?) Old style Sony looms (Like for my headunit) had a seperate battery for it's memory in the loom so the full-time feed would keep that charged and the Acc position would have swiotched it on and off.. My "professionaly installed" supposedly "Sony" replacement loom doesn't have the battery so my head unit just re-sets itself every time I switch off the Ign.. And both front speaker connections in that loom are intermittant as well! :mad: (avoid CCA in Aylesbury like the plauge is my advice) Off to see if I can get a proper loom for it from a reputable Sony dealer this week! HTH... Quote Share this post Link to post Share on other sites
