jedi-knight83
spark plugs -----again
i see this has been talked about before to an extent but i didnt see the answer i was looking for.....
I can get 6 x NGK plugs at the following prices
BKR5EKUP for £31.74 (platinum)
BKR5EKU for £15.54 (normal)
Which ones should i get? are the plats worth double the price??
I've used both the Bosch and NGK plugs, no difference between the two, running wise. The NGKs have wider gaps than the Bosch plug but the engine feels the same using either.
K
which ngk's did you use? the plat's?
Just the regular ones. You can try the platinums if you like, you won't notice a performance boost but they'll last longer than regular plugs, which I think is the whole point of them.
Kev
