g60karmann 0 Posted June 11, 2008 Had a bit of a scare approaching a roundabout a touch too fast, I was braking down heavy from around 85 in a straight line and then the rear swung out to the right badly!! had to do some drastic recovery to keep it on the road. I was told at the MOT not so long ago that the rear beam bushes could do with replacing, I also have new tyres (covered around 600 miles). This isn't the first time the rear end has been unpredictable but by far the worst! Anyone got any idea what could be causing this? My thoughts are either wheel alignment, rear beam bushes, dodgy brake line? All thoughts appreciated Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted June 11, 2008 has your car been lowered? have you adjusted the rear brake bais to compensate? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted June 11, 2008 has your car been lowered? have you adjusted the rear brake bais to compensate? Is that to compensate the lowering? how do you adjust the brake bias, how do you adjust it and how much? Thanks Quote Share this post Link to post Share on other sites
g60karmann 0 Posted June 11, 2008 ah something I forgot to do! will give that a go tonight and see how she fairs :salute: cheers for the quick response Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 11, 2008 had the same happen to me, i knew i was meant to adjust the bias valve but completely forgot as i was too excited about the ride height and wanted to take it for a spin, but ended up actually taking it for a spin when pulling up to a junction, i ended up facing the opposite way in front of a lorry :shock: worn rear bushes also wont help. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted June 11, 2008 had the same happen to me, i knew i was meant to adjust the bias valve but completely forgot as i was too excited about the ride height and wanted to take it for a spin, but ended up actually taking it for a spin when pulling up to a junction, i ended up facing the opposite way in front of a lorry :shock: worn rear bushes also wont help. Where's the bias valve and how much do you need to adjust with a 40mm drop? I need to get mine adjsuted. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted June 11, 2008 has your car been lowered? have you adjusted the rear brake bais to compensate? Is that to compensate the lowering? how do you adjust the brake bias, how do you adjust it and how much? Thanks[/quote:142ooakr] yes as the brake bias just thinks you have been to tesco to stock up on booze and the boot is full,has more weight on the rear end and more braking on the rear end,fine with weight but a lowered raddo with no weight is wavey under heavy braking. There is a 13mm m8 bolt nut attached to the compensator spring,this bolt sits in a slot that can be adjusted.......and I cant remember which way as i adjusted my brakes on the MOT brake rollers at work,just have a play and find out. edit...i take no responsibility for your braking antics on the public road. :tongue: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted June 11, 2008 has your car been lowered? have you adjusted the rear brake bais to compensate? Is that to compensate the lowering? how do you adjust the brake bias, how do you adjust it and how much? Thanks[/quote:rrgat4cz] yes as the brake bias just thinks you have been to tesco to stock up on booze and the boot is full,has more weight on the rear end and more braking on the rear end,fine with weight but a lowered raddo with no weight is wavey under heavy braking. There is a 13mm m8 bolt nut attached to the compensator spring,this bolt sits in a slot that can be adjusted.......and I cant remember which way as i adjusted my brakes on the MOT brake rollers at work,just have a play and find out. edit...i take no responsibility for your braking antics on the public road. :tongue:[/quote:rrgat4cz] Where's the compensator spring? :oops: Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted June 11, 2008 jack up your passanger rear wheel and look just in front of the axel,you will see the compensator with all the brake pipes going into it aswell as the spring. Quote Share this post Link to post Share on other sites
Yandards 0 Posted June 11, 2008 It could also be seized. Quote Share this post Link to post Share on other sites
