Aus 0 Posted December 2, 2003 My rear window steams up whenever the car's stopped for a minute or so. There's no wet carpets/leaks from all the usual culprits and I've checked door membranes, door drain holes, heater matrix, rear light seals etc. The 2 front drain holes on the sunroof are fine, but I remember reading somewhere that there are 4 drain holes in the s/r? How do you get to the rear 2? Cheers ***Mod Edit: I've removed the other version of this post as it was identical to this one. - Henny *** Quote Share this post Link to post Share on other sites
Ady_G 0 Posted December 2, 2003 When I unblocked my sunroof drain holes I thought there were only 2, 1 either side of the black plastic gutter. Cheers Ady Quote Share this post Link to post Share on other sites
bootsy 0 Posted December 2, 2003 there are 4 tubes that run down each pillar to get to the rear ones i'm afraid you need to drop the headlining out , but its no big task really they gan be simply checked by pouring water around the sunnroof when opened with the car on level ground , about a large mug full in each corner should do it you will see it pour out under the car in the relavant corner if the tubes are clear and attatched Quote Share this post Link to post Share on other sites
Henny 0 Posted December 2, 2003 Just out of curiosity, does the rear washer work? It's quite common for the pipe to rip around the hinge in the bootlid causing it to leak water out... This could cause your rear window to steam up... :? Quote Share this post Link to post Share on other sites
Aus 0 Posted December 2, 2003 I've poured water into the sunroof gutter and it came out fine. And the rear washer is working and all the piping was dusty and dry so guess that's OK. I'm absolutely stuck why the window steams so quick - have just run sealant all round the inside of the rear window, more in hope than anything else! Quote Share this post Link to post Share on other sites
Riki 0 Posted December 2, 2003 Poor seal on the roof anntena? Rear light seals? Tailgate hatch grommets? Boot lock barrel seal? You would really need to get someone to hose it down while you lie inside with a torch and look for ingress. Quote Share this post Link to post Share on other sites
Republic Of Mancunia 0 Posted December 2, 2003 I also have the same problem m8, if you discover the problem let me know, I’ll be getting hosed down at the weekend so if I discover where mine is coming from I’ll let u know. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 2, 2003 Are you sure you actually have a leak? Hot air will naturally condensate on a cold surface. My rear window also steams up when I get in it on a cold morning but 1 minute of the demister, and it's completely gone. I also have the window open all year round, so the temperature inside the car equalises quicker. My car is a bone dry inside and that's the only theory I can come up with, sorry if sounds stupid or teaching you to suck eggs! Kev Quote Share this post Link to post Share on other sites
