Kempy
Refitting rear seatbelts
I found it easier to get to my rear struts by taking out my rear seatbelts now I cant refit them as they seem to have locked up. Is there something I can do to help? cheers :wave:
Bolt them into position again :scratch:
Sounds strange but I bet it works ....
You need to make sure that the reel is exactly the same way up as it is when it's bolted in the car - then gently rock the belt back and forward and it should release and pull out.
Edit: They're designed to lock if they're not the right way up on the assumption that the car must have rolled and you would rather like to be kept in place...
