brian g60 corrado 0 Posted December 8, 2003 as title says new coolant no heat in car.its a g60 raddo with the valves in coolant hoses that go to the matrix.head gaket previosly done was ok before i changed coolant.is there a method to bleed the trapped air.cheers. :shock: Quote Share this post Link to post Share on other sites
g60bv 0 Posted December 8, 2003 it will be air just dont over heat the car cos you'll damage something, i had the same prob when i had my head off, and damaged both coolant senders, i'mn sorry but i cant remember how i got it out thou, i sure running it slowly sould clear it. ?? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted December 8, 2003 try running the car with the expantion bottle cap off and the heaters on full you should then see the air bubble out of the bottle Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 8, 2003 Did you put the heater on hot before the change?? Quote Share this post Link to post Share on other sites
Andy T 0 Posted December 8, 2003 Putting the heater controls on full only applied to the golf mk1 matrix which had a valve on it. Mk2/Corrado matrix's flow coolant all the time, the heater control just opens an airway flap. I spent ages looking for that valve until someone told me this! When you say valves in the hoses, do you mean the pressure relief valves that were done as a VAG recall? I thought it only applied to the mk2 golf? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 8, 2003 Putting the heater controls on full only applied to the golf mk1 matrix which had a valve on it. I see, yeah that makes sense, cheers for the tip :) Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 9, 2003 thanks for all replies.yes had the heater control on hot,as you look at hoses there is an alloy vale on top and a black valve on bottom hose.now is it a case of removing one of the hoses to remove the traped air.and which one any suggestions would be cool.also have tried running engine with ex cap off still no heat. Quote Share this post Link to post Share on other sites
slot 0 Posted December 9, 2003 Is there a bleed valve on the highest hose ???undo it a few turns ! that should get rid of your air lock ! :) Quote Share this post Link to post Share on other sites
Andy T 0 Posted December 9, 2003 Sounds daft but have you actually driven the car yet or just run the engine? When ive done coolant changes, the pressure release recall valves don't let anything pass with it stood there idling, but when I took it out for a run it seems to sort itself out. Let the engine warm up, then feel the pipes before and after the valves to check for temp differance. If the return hose from the matrix is cold, there is no flow of coolant through the matrix at all(probably caused by a seized recall valve) Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 10, 2003 o.k. should i buy new recall valves or is it safe to remove them and just use normal tubing.is anyone running g60s without these valvesand mainly is it SAFE. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted December 10, 2003 vw started fitting the valves on a recall,incase the matrix failed the valves would shut off and stop your feet from being scalded,so i would repace them if i were you Quote Share this post Link to post Share on other sites
Andy T 0 Posted December 11, 2003 o.k. should i buy new recall valves or is it safe to remove them and just use normal tubing.is anyone running g60s without these valvesand mainly is it SAFE. like dazzy vr6 says, i wouldn't bin them. Make sure they are definately the source of the problem, take them off the car and try and run a hose pipe through the hose with the metal valve. If they are goosed you will have to buy new or source some from a breakers. Quote Share this post Link to post Share on other sites
brian g60 corrado 0 Posted December 11, 2003 cheers for replys have taken them off and fitted plastic tubing for now. checked the valves by blowing through them and found that the metal one wasent working properly so cleaned and knocked it about a bit ,now flows better and may refit at a later date after i flush system properly. Quote Share this post Link to post Share on other sites
crdo16v 0 Posted February 15, 2004 I had major probs. with no heat coming thro', after major hassle it turned out that the black plastic heater by-pass valve had been fitted the wrong way up! Quote Share this post Link to post Share on other sites
