Kempy
Door mirror glass removal
Hi I've done a search on this and cant see a lot about it, Do I need a special tool? cheers Kempy :D
No special tool required! Just a large flathead screwdriver to pop the glass out. I find the easiest way to do it is to angle the mirror as far upwards as possible and then get the screwdriver in the gap left at the bottom of the mirror. Once you have the bottom clips un-popped, the top ones come out pretty easy.
Yup, be carefull when unplugging the wire to the glass as part of the spade connector can easily snap!
