dubweiser
brighter bulbs.....without the wiring loom
So wht are results like anyone running uprated bulbs on the factory loom
my lights are so poor thinking of getting some Halfords bulbs as they are on offer at the moment
I had 50% bulbs in and had a loom problem so went back to standard wiring, it is utter pants, shockingly bad in comparison, even frightening!
I would fit the loom as my first upgrade if i ever had to get another Corrado, then the wipers! 8) 8) 8)
Bright bulbs with a standard loom is money wasted in my opinion, why spend £20 ish on a pair of bulbs and then not power them correctly???? :nono: Madness!
thats just an opinion though matey i am sure its even better with the headlight loom but there must be owners that just run the brighter bulbs with a standard loom
Well if you read the thread .......
hi all, was gettin fed up of the dull beams so i went and bought philips xtreme power H4 12v 60/55w and they are so much better. no upgraded wire loom needed for me.
jimmy was happy with just the H4 bulb upgrade. :wink:
Found this offer on ebay mate if it's any use to you: Ebay
For that price and free sidelights u can't really go wrong
Excellent, thanks a lot!! Ordered straightaway.
As above, the standard loom is flawed but I got so fed up with the unrelaibility of the trimsport one I had that I've pulled it out and gone back to stock...
Seriously? It's a peice of p1ss to make a proper 4 fuse, 4 relay loom mate. Doesn't take long either and saves you £50 on switches every couple of years.
4 fuses and 4 relays (1 per bulb) seems a tad over kill, but I like to have 3 bulbs remain working if one fuse blows, unlike some other shared fuse/relay looms that take the whole lot out if one fails.
For a nice spec loom, simply get:-
4 of these - http://www.autoelectricsupplies.co.uk/product/170
1 of these - http://www.autoelectricsupplies.co.uk/product/181
Some of this - http://www.autoelectricsupplies.co.uk/product/70
And some of these - http://www.autoelectricsupplies.co.uk/product_list/2
A pair of head light plugs from Neil
It can be built for a lot less money obviously. Even with standard voltage bulbs, a replacement loom makes a difference!
I'm really glad I took the time to build my own (IRO 15-20 quid), although I've now gone to Phillips Extreme 55/60W bulbs from the 100/80's I originally used, the loom has been totally reliable for nearly 10 years and there's no voltage drop compared to the full VW wiring.
Do it yourself, take the time to carefully seal and protect every part from the elements and you'll be pleased with the result regardless of which bulbs you fit, standard or uprated.
I don't drive much on full beam, but for piece of mind for longevity of the reflectors it's best to stick to standard wattage but higher output, as I think the plastic reflectors would deteriorate far quicker on the heat from 80W dip all the time than a 55W standard or Phillps Extreme etc type bulb.
Whatever you do, protect the relays, I've seen far too many tie-wrapped behind the front grille and headlights, soaking up the salt spray :nono:
The loom is the weak link... send current 1/2 way round the car into the switch, which also means the switches fail. Upgrade looms means the current go from Battery straight to bulbs, less Voltage drop.
Halfords 50% Brighter bulbs are pretty good... still pull stock Wattage (so no smoking looms) and ae a bit brighter. Used for 2winters.. need to be replaced though...
Phillips ?Extreme? are also supposed to be 70% brighter
Just remember all bulbs lose brightness over their lifespan... So if they've been in a while replace...
i went to halfords and got 90% brighter bulbs and they are brilliant. £20 for both bulbs
Hi incase anyone is interested....saw this deal on the web http://www.powerbulbs.com/product_detail.asp?prod=43
Looks like a good deal with free side lights aswell.What do ya trhink?
ALSO 10% OFF WITH THIS CODE ( KAFFE1746 JUST ORDERED MINE) JUST ORDERED PHILLIPS FROM THERE
Just done the same as HID kits are rather pricey. Hopefully these will do the trick :wink:
Excellent, thanks a lot!! Ordered straightaway.[/quote:3evfeqoi]
I ordered these and have just fitted them, the sidelight bulbs don't fit (I have LHD headlights) so I have to order slightly different ones.
I'm yet to use them, hopefully I'll be able to see at night now :D
I'm yet to use them, hopefully I'll be able to see at night now :D[/quote:3s7oyqr9]
Yeh the sidelight bulbs are'nt the right ones, but will fit in the 'side' interior light. Well f*ckin' bright lol!! :lol:
Can you buy the uprated looms from anywhere or are they all home mades?Has anyone got a wiring diagram of how to put one together...?
there is alot of chit chat on what brighter bulbs to use, but no one posts up pictures of the results for others to see or judge by themselves.
well here is my pictures of my 4300K hids installed with 3 relays to power up each pair of beams, high, low, and fogs. post up your philips guys.
232323232%7Ffp53842%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338878277345nu0mrj
232323232%7Ffp538%3A9%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338886%3A42345nu0mrj
232323232%7Ffp5383%3B%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D333887827%3A345nu0mrj
232323232%7Ffp538%3A9%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338886%3A43345nu0mrj
232323232%7Ffp537%3B8%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D333887827%3B345nu0mrj
232323232%7Ffp53832%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338886%3A44345nu0mrj
232323232%7Ffp538%3A%3A%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338878283345nu0mrj
hmm, what is leaking now?
232323232%7Ffp537%3B4%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338886%3A45345nu0mrj
232323232%7Ffp537%3B6%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338878285345nu0mrj
232323232%7Ffp537%3C4%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338886%3A46345nu0mrj
HID on, yes 4300K
232323232%7Ffp537%3B4%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338878287345nu0mrj
232323232%7Ffp537%3C6%3Enu%3D53%3C3%3E733%3E254%3EWSNRCG%3D3338886%3A47345nu0mrj
That doesn't show anything! Besides going completely off thread with half a dozen pics of your car leaking, you've shown headlight pictures in broad daylight! :cuckoo:
And they can't be that bright as your camera flash went off!
okie dokie :clap:
Nice looking kit, looking at the fused relays it says they won't fit into that relay box though.
