jamie p
Can't open bonnet. Help please
Hi need a bit of help. The bonnet release cable has broken how can i open the bonnet without this?. Help please Jamie
can you see if it has broken by the bonnet lever if so get some big plyers and pull the wire manualy
if not go via the grill like mentioned above !!
Cheers Swift. Moving and closing as this has been more than covered already if you use the wiki or search.
