chrishill 0 Posted December 19, 2003 front or rear? apparently the rear calipers are prone to seizing, mine does it too if i've had the handbreak on for a while. - quick fix: grease the break disk's! :D Quote Share this post Link to post Share on other sites
TDK 0 Posted December 19, 2003 right the handbreak light comes on when you pull the handbreak on when you take handbreak off the light goes out but can flicker very slightly? i think its the front breaks they dont' squeall the time just do a bit Quote Share this post Link to post Share on other sites
stormseeker 0 Posted December 19, 2003 Re: squeaky breaks any ideas? fix it? (sorry - couldn't resist - pun on your mispelling of brakes ;-) ) Quote Share this post Link to post Share on other sites
MT 0 Posted December 19, 2003 If its not too bad you could try taking out the front pads and putting some copper grease on the areas of the pads that make contact with the caliper (not the disk!!). This helps stop the squeeking noise caused by the vibrations i believe. good luck Quote Share this post Link to post Share on other sites
TDK 0 Posted December 21, 2003 lol didn't see that DIRE! spelling mistake ha ha my mind was on music! Quote Share this post Link to post Share on other sites
