Blackburry 0 Posted March 14, 2009 Im working on a 90 G69 I have fuel and power to everything. i have power to the coil and the hall sender plug. but i have no spark from the coil even changed it to a new one. also got new spark plugs, wires,cap, and rotor all ground are good.. Timing is set it turns over but no spark. :( anyone got any answers? :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 14, 2009 Broken distributer shaft or knackered hall sender? Welcome to the forum btw... Quote Share this post Link to post Share on other sites
Blackburry 0 Posted March 15, 2009 i have changed everything: Distributor, cap, rotor, plug, wires, even digifant still no spark. am i missing something?? HELP!!!!!! :scratch: :confused4: Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted March 15, 2009 How are you checking for a spark btw? Maybe change thye ecu relay or the ignition switch. Have you definately got 12 volts to the coil? Maybe 1st check with the help of a mate that you have a voltage to the coil black wire while cranking.. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 15, 2009 As above have you changed the ECU power relay and ignition switch? Quote Share this post Link to post Share on other sites
Blackburry 0 Posted March 15, 2009 gettin relay tomorrow Quote Share this post Link to post Share on other sites
flusted 0 Posted March 16, 2009 check for the live at coil on cranking, as above could be ignition switch Quote Share this post Link to post Share on other sites
Blackburry 0 Posted March 19, 2009 well i got it running but now fuel pump doesnt work. if i run a hot wire it runs but its not working with the key anymore any ideas? :mad2: :confused4: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 19, 2009 Again - have you changed the ignition swict and the fuel pump + ECU relays?? Quote Share this post Link to post Share on other sites
Blackburry 0 Posted March 19, 2009 changed switch and relay.. fuel pump was workin before u could hear it before u cranked car now just nothing Quote Share this post Link to post Share on other sites
Mawrick 0 Posted March 19, 2009 Are you 100% positive all your grounds are ok?....... Also if you haven't done it I would remove the distributor cap to check that the rotor is still in it's place, I had it once fool me when it had jumped of it's rod........ Quote Share this post Link to post Share on other sites
