Jon_vr6
exhaust heat shield clips
Had an annoying rattle every now and then coming home from work today had a look above the exhaust and noticed that the spring clippy things that hold the heat shield near the tailpipe have gone through the heat shield resulting in it rattling on the exhaust. All i want to know is where to get and what the clippy things are called?? Are they readily available??
Cheers
Jon
If you mean the little circular spigot ring things, then they are:
N 90335004
clamping washer
5X30 /
Hope this helps,
Jon.
Are these available in another metal type? (isn't the "going thru" caused by the 2 metals reacting with eachother?).......
IIRC the shield is aluminium, and those washers are steel.......and "eating" through the shield...;)
What were vw thinking when they made them out of 2 different metals tut tut!! Getting mine from the stealers!!
My heat shiled rattles a bit in the mornings ie when the car is cold and only on revving it slightly. Is there any kind of packing or wadding that can be used to stop this, in addition to the clips? Of course it needs to be heat resistant.
I think it's quite a common problem, not only VW.......:(, but yea, what where they thinking..........lol
Can anyone confirm the right part number just checked on mates etka and the part number (used on other parts of car aswell) is
N 907 965 02
clamping washer
just thought it was weird as the part number above is different!
Jon
Had this with mine...
Problem being is that the Ali shield's probably been eaten through to size of the clips...
Solution... Silicon Tie Wraps! :clap:
My Rear most one had gone so I tied it through the "Body mount" (bit they use at the factory to move cars about) next to it... been over a year like that and all's good!
Now I've said that... watch it break :norty:
