mikehiow 0 Posted March 25, 2009 Good evening all, I've been attempting to read my ABS codes with VAG-COM, to no avail. I have a cheap eBay job lead, and an old "registered" version of vag-com (311). It reads the engine codes fine, but cannot seem to read the ABS codes. I seem to remember reading that the ABS module/vag-com was fussy about which com port you used and/or the selected baud rate, but cannot seem to find any reference to this now. Can anyone help? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 25, 2009 Go to device manager in windows and select the com ports device and click properties.... the baud setting is in there. :) Quote Share this post Link to post Share on other sites
mikehiow 0 Posted March 26, 2009 I know where the Baud Settings are, my question is, should they differ from 9600 for ABS? Quote Share this post Link to post Share on other sites
mikehiow 0 Posted March 28, 2009 bump, any suggestions? Quote Share this post Link to post Share on other sites
Toad 0 Posted March 28, 2009 There's a thread about this already. It's the latency settings on the USB/OBD adapter. Have a search on here for "latency" and you shoudl find the thread. Quote Share this post Link to post Share on other sites
millerman 0 Posted March 28, 2009 if your still having problems i have a proper vagcom lead and can help im in farnborough let me know kel Quote Share this post Link to post Share on other sites
mikehiow 0 Posted March 28, 2009 Thanks for the kind offer millerman, I have a friend with a snap-on tool, I just wanted to get mine working. Also, Thanks Toad, I'll look it up :) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 28, 2009 Really? I would have thought that if the engine ECU works on your lead and VAGCOM combo then the ABS ECU would too. Does your ABS work anyway? Tried re-seating the ABS ECU controller connector? Quote Share this post Link to post Share on other sites
Toad 0 Posted March 28, 2009 dr_mat said: Really? I would have thought that if the engine ECU works on your lead and VAGCOM combo then the ABS ECU would too. Does your ABS work anyway? Tried re-seating the ABS ECU controller connector? A lot of the cheap cables have issues with too many comunication errors when connecting to the ABS Ecu, changing the latency settings seems to sort this issue out though. Quote Share this post Link to post Share on other sites
mikehiow 0 Posted March 29, 2009 dr_mat said: Really? I would have thought that if the engine ECU works on your lead and VAGCOM combo then the ABS ECU would too. Does your ABS work anyway? Tried re-seating the ABS ECU controller connector? I had it read a while ago, there were three errors, although I forget exactly what they were, something about a valve, amongst other things. No, my ABS doesn't work. I assume the plug you speak of is on, or around the ABS pump somewhere? I will change the latency settings (5 for the record) tomorrow, and give it another go. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 29, 2009 mikehiow said: No, my ABS doesn't work. I assume the plug you speak of is on, or around the ABS pump somewhere? I will change the latency settings (5 for the record) tomorrow, and give it another go. You mean the ABS light is on? Or no lights, no-one's home ..? The plug is on the control box, it's in the passenger footwell, against the outer shell of the car. Though it's probably a good idea to go check the connections on the pump/valve block under the bonnet too. TBH if you've had a "valve error" chances are the valve block is hosed and you'll need to replace it. That's no big deal, there's plenty on scrap yards (good supply means low prices) and they're usually quite reliable. Quote Share this post Link to post Share on other sites
mikehiow 0 Posted March 29, 2009 Cleared and checked today, the issue shows it's self the moment the engine is started. Front right valve, and near left valve are showing up in the fault codes. There was a brake pedal position sensor fault, too, but it didn't return after clearing the error (It had been cleared about 4 weeks previous, however). Looks like it's a new ABS block then. It seems every time I fix a problem, another arises. Since changing my full ignition system, it's become apparent there is excessive oil in no.1, my clutch master cylinder needs doing, as does the ABS. For reference, changing the latency to 5 did the trick (device manager, properties for relevant com port (or usb->serial device), advanced settings). Quote Share this post Link to post Share on other sites
