Kempy
door mirror refirb
can you remove the black plastic around the edge, just to help when Im painting?
Also if the plastic is a bit scratched can you do much with it? or has it had it?
Cheers
yes u can remove it,u need a thin screw * driver. u got tilt the mirror glass to the side and u'll see the screw (undo them) there should be 3/4, then remove the glass by pushin in the tabs and thats it.....
bob (was awhile since i did mine thou)
bob
oh yeh, u can flat and paint the black it or get texture paint
