Kevin Bacon
Sunroof panel alignment - Bentley manual needed!
Does anyone have the Bender manual to hand?
I would like to know the sunroof panel alignment details if you'd be so kind?
The front and rear of the panel needs to sit proud or recessed a specific amount in relation to the roof line. I'm sure 1mm proud at the rear and 0.5mm proud at the front rings a bell.
I think if they sit dead flush (for neatness) or too recessed, the panel liner rubs on the interior aperture seal and binds, causing the motor to stop.
Just want to test the theory on mine but need the details, cheers :D
What a conicidence I was just printing out the sunroof section of the factory manual!
Front height
1mm below roof line
Rear height
1mm above roof line
