joinerboy
Bleeding brakes
i need help! i spent hours today bleeding my stupid brakes. no matter how many times i do it theres still air in there.
i have new calipers all round with new copper pipes so i have to bleed the whole system.as far as i can tell the new lines are all tight. i cant see any leakage anywhere.
is there a special way to bleed the entire system on a vr6? or should i just keep on pumping endless amounts of fluid through the system?
help pls :(
mine took ages to be fair. kept having to bleed the master cylinder on the 2 screws.
as a rule of thumb always start the corner furthest away from the master cylinder. e.g. OSR then NSR, OSF,NSF if all else fails mayb pressure bleed it. but i dont know as to any special way with corrados, hopefully someone else can help you on that one.
oh and open up the bias valve on the rear axle, think you have to let it hang.....someone correct if wrong. i left the connections loose until fluid dripped from them to avoid an air lock.
You are pressure bleeding right??? If not you need to be as it's an ABS car...
I use about 20PSI to get good flow and the order is (on a UK RHD car with ABS)
Rear right, Left, front right, front left then MC and don't forget the clutch too!
If you have got air into the ABS system or still having major probs then I'd just take it to VW.
My tip is to get it most of the way there and then get it professionally pressure bled, save yourself the time and hassle plus the waste of brake fluid doing it on the drive.
Don't forget to bleed the ABS pump after doing the calipers but before the master cylinder. It can also help to activate the ABS pump (by braking really hard) and bleeding again. A pressure bleeder is a must though.
thanks for replies guys. so the conventional method(releasing nipple,pressing brake peddle) doesnt work?
i never thought of bleeding from the master cylinder. i will try that
as far as the abs pump goes i havent a clue. where is it located and how do u bleed it :lol:
im going to check my manual now
Go and buy an Eezibleed kit from Halfords mate - you will damage the master cyl doing it manually and they are £250 to replace!
crack off the pipes that go into the abs unit 1 at a time. 2 pipes go into it, and 4 come out and go to the calipers.
bleeding the brakes manually shouldnt damage the MC, could potentially turn the seals but very unlikely. i dont like using pressure bleeds personally as your forcing air into the fluid. but some of the cars iv worked on in the past have needed you to use these. so swings n round abouts i guess.
What :cuckoo:? Just use the two bleed valves on the top of the ABS pump, which is located under and to the left of the coolant expansion tank.
Nothing like a bit of thread resurrection for a Monday afternoon.
I'm gonna fit my Brembos tomorrow, and was just thinking about the easiest way to bleed them.
If I ensure that the fluid level is kept topped up in the resevoir, and because I'm only doing the fronts: am I correct in thinking I can just disconnect the brake line from the hard line, connect the new one attached the calliper and then release the bleed nipple on top of it.
There shouldn't be any air in the system apart from in the new parts right? so in theory I could actually attach the hoses to the hardline with the calliper bleed nipple already open, and this would force the air out, so when fluid starts coming out they're done!
Sounds easy right!
Let me know if there are any holes in my plan! ( I do have an eazibleed should I need, but just thought this sounded like a pretty straightforward plan)
Andy
Sounds easy right!
Andy
in theory that works, but tbh, you'll probably find that you need to do the rears as well - air has a nasty habit of finding it's way in when you've got the system open...
try by all means obviously - if it was me though i wouldn't waste the time and i'd just bleed the lot from the off. at least you know your fluid is totally 100% then too.
if you have any eezibleed kit then you're laughing anyway!
i did mine and my clutch a couple of weeks back and checked the other day and the clutch is on the floor (the car hasn't been started), now when i press the clutch i can feel resistance, does turning the engine prime the clutch?
no, turning the engine over doesn't affect the clutch.
sounds like the master has had it...
which did you replace - guessing it was the slave?...
do you just mean the bit of rubber flexi covered in blue fabric that runs from the reservoir to the master?
that shouldn't make any difference at all!
your problem has come from bleeding the system by the sounds of it... first try and re-bleed the system.
however from what you've said, i sunds like something has failed somewhere, or possibly you haen't tightened something back up 100%.
try a re-bleed and get back to us...
