big ben
how do you remove the dash speaker grills
yep, but do it gently from different angles with something fairly broad (i.e. not a screwdriver)
there are barbed plastic lugs at each corner that need to be popped free of the dash
you might even just pop them out with your fingers, just push from the outside to the inside from one corner to the next, mine tend to pop out if I squeeze my fingers in the gap between the dash and the grille edge
I got myself a couple of sets of these for this sort of job, far less likely to mark adjacent surfaces than a screwdriver or metal rule:
http://cgi.ebay.co.uk/CAR-INTERIOR-DASH-DOOR-TRIM-PANEL-REMOVAL-PRY-TOOL-KIT_W0QQitemZ230340547999QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item35a15dd59f&_trksid=p3286.c0.m14
Also good for 'exploratory' work as well because they normally bend before the panel snaps.
I don't recall which seller on eBay I actually used.
....good tip, I'm constantly cursing when I scrape interior parts trying to remove them !!
