Europolo 0 Posted August 30, 2009 In trouble... the corrado has been parked up outside for the past few months and has took on alot of water... Its all gathering in the rear footwell (passenger side) and theres loads of it.. a couple of inches when I sponged it into a bucket :( Now ive heard people on about the membrane behind the doorcards but I was kind of thinking it could be the heater matrix no? Any one want to try diagnose the problem? whats most likely? If you think its the matrix, wheres best to get one? Its a non air conditioning VR6 Any help would be much appreciated.. Thanks Cliff Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted August 30, 2009 I would check the front scuttle panel fresh air intake. What sometimes happens is the scuttle drains block with leaves, then it rains and the scuttle area fills with water and it leaks through the air intake seal. I would take the air intake off and replace the seal and check the drains are not blocked. Good Luck :D :D Quote Share this post Link to post Share on other sites
VR6 0 Posted August 30, 2009 Why would you disregard the obvious options of door membranes and scuttle drain etc and jump to the conclusion of heater matrix? The matrix tends to favour the driver's side and you would (should) be able to tell because it's coolant rather than water! Order I'd eliminate things: Scuttle cover/drain Passenger door card/membrane Other seals like the windscreen and sunroof (checking using a hose) Matrix is a whole other job! Quote Share this post Link to post Share on other sites
Europolo 0 Posted August 30, 2009 Ill get a look at that later on... Dont think its the door membrane... beacuase the carpet along the sill when you open the door is dry... Its all just gathering in the back... At the seat rails... Ill look into the scuttle cover... I put a mk2 jetta scuttle cover on a few months back, better check its not diverting water in anywhere... thanks... Quote Share this post Link to post Share on other sites
VR6 0 Posted August 30, 2009 Where it comes in past the door cards (or from the bulkhead area), doesn't necessarily mean that the front carpets should be wet. It's quite easy for the water to run to the back if it's on a slope and the back of the carpets is pretty coarse so the fronts could get away with being pretty dry. Quote Share this post Link to post Share on other sites
PROVR6 0 Posted August 30, 2009 Had the same problem in the same location. It was the air intake in the scuttle panel blocked with leaves and the seal had perished. REplaced with a new seal and some sealent for good measure and its been fine since. Deffo check that first. Quote Share this post Link to post Share on other sites
Europolo 0 Posted August 30, 2009 Dont suppose you have the part number for the seal please, no? Quote Share this post Link to post Share on other sites
dragon green 5 Posted August 31, 2009 this should help http://wiki.the-corrado.net/changing_he ... _seal.html pollen filter cost me £23 ! i hoover under the scuttle at least once a month Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted August 31, 2009 Do the pollen filters fit the standard leaf guard or is there a later filtered one??? Quote Share this post Link to post Share on other sites
dragon green 5 Posted August 31, 2009 they only do one for the Corrado,they did say its tight, but it fits ! i will do mine next weekend, Quote Share this post Link to post Share on other sites
Europolo 0 Posted September 2, 2009 Super... thanks for the link... Quote Share this post Link to post Share on other sites
Europolo 0 Posted September 14, 2009 Bad news... Had a serious root around today.. Its the heater matrix for sure... Its constantly dripping out from under the dash. The heater intake was clear and the door membrane's are grand... So where can I get a matrix guys? its for a non air conditioned VR6? Thanks Quote Share this post Link to post Share on other sites
dragon green 5 Posted September 15, 2009 gsf, the stealers Make sure its a valeo one, good luck Quote Share this post Link to post Share on other sites
Europolo 0 Posted September 15, 2009 Please excuse my ignorance... Whats a valeo one? I actually popped into my local motor factors and they had it listed in their catalogue... 40euro... about 35 punds sterling... Souns way too cheap surely?! They said its listed as a heater radiator for all corrados... and is same as a mk2 one? True? Quote Share this post Link to post Share on other sites
captainredeye 0 Posted September 17, 2009 i wrote this on another topic on water leaks as i had the same problem! Check under the ecu just under the windscreen, there is a little hole dont know if a rubber bung goes there but i blocked mine up with a small screw and some dum dum. problem is now solved hope this helps. Quote Share this post Link to post Share on other sites
Jay23Sx 0 Posted September 17, 2009 Please excuse my ignorance... Whats a valeo one? I actually popped into my local motor factors and they had it listed in their catalogue... 40euro... about 35 punds sterling... Souns way too cheap surely?! They said its listed as a heater radiator for all corrados... and is same as a mk2 one? True? Valie would be the make. GSF have it listed at £38 so the factors are around the right price. GSF only list one for the Corrado so it appears to be the same one in all models. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted September 17, 2009 GSF only list one for the Corrado so it appears to be the same one in all models. All the same as the Mk3 Golf! Quote Share this post Link to post Share on other sites
st4stokie 10 Posted February 21, 2014 I've got this problem in my passenger rear footwell. Just picked something up out of the car and it was wet, had a feel under the carpet and the soundproof is soaked. The water is abit oily/sticky which I'd say was coolant but I'm not loosing any coolant from the expansion tank so would I still be looking at heater matrix? How big a job is it to replace Quote Share this post Link to post Share on other sites
Ray1965 10 Posted February 21, 2014 I've got this problem in my passenger rear footwell. Just picked something up out of the car and it was wet, had a feel under the carpet and the soundproof is soaked. The water is abit oily/sticky which I'd say was coolant but I'm not loosing any coolant from the expansion tank so would I still be looking at heater matrix? How big a job is it to replace http://the-corrado.net/showthread.php?t=23872&highlight=heater+matrix this might help, to show how bigger job it is, good luck Quote Share this post Link to post Share on other sites
st4stokie 10 Posted February 22, 2014 Thanks for that ray1965 Quote Share this post Link to post Share on other sites
