ben boy 0 Posted September 3, 2009 hi all , i need some assistance on my g60 , my heater only is working on fan speed 1 ? :confused4: as its becoming :censored: weather the inside gets moisture on inside of window and can not clear it withoiut a heater . i have been told its the resistor pack , but i dont wanna go buying one if its not the problem , couls someone please help me with this :help: :help: thanks ben ,, Quote Share this post Link to post Share on other sites
dragon green 4 Posted September 5, 2009 Use the search ! the search is strong on this forum :wave: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted September 5, 2009 "only works on full speed" is a failed resistor pack. "only works on fan speed 1" is a completely different problem, and is a very weird one at that. More details please! Quote Share this post Link to post Share on other sites
dragon green 4 Posted September 5, 2009 early or late interior ? Quote Share this post Link to post Share on other sites
shaung60 0 Posted September 5, 2009 A G60 will be an early interior. Quote Share this post Link to post Share on other sites
ben boy 0 Posted September 6, 2009 early interior , only works on fan speed 1 , thanks Quote Share this post Link to post Share on other sites
bilboe43106 0 Posted September 10, 2009 HI I HAD THIS PROBLEM WITH MY 16VALVE IT WAS THE ROTARY SWITCH IN THE DASH THAT WAS AT FAULT TO TEST IF ITS THE SWITCH REMOVE THE FACIA AND PRIZE OUT THE SWITCH AND REMOVE FROM THE WIRING BLOCK ON THE WIRING BLOCK MINE WAS MARKED WITH THE SPEED POSITIONS 1 ONWARDS AND THE ONE THATS NOT IS THE FEED WITH IGNITION ON I USED A SHORT BIT OF WIRE TO TO BRIDGE FROM THE FEED TO THE SPEED TERMINALS IN TURN IF YOU GET ALL SPEEDS ITS THE SWITCH. ABOUT £13 FROM VW Quote Share this post Link to post Share on other sites
