bad-vw-boy 0 Posted September 3, 2009 will coilovers fit across the corrado range or do they fit certain years or models? i have seen some on pistonhead but unsure of the make just wanted to know if they fit as they came off a corrado not sure what model, trying to find out, any suggestions Quote Share this post Link to post Share on other sites
Jonny777 0 Posted September 3, 2009 Will fit them all mate. Same with Rado's, mk2's and mk3 Golfs. :) Quote Share this post Link to post Share on other sites
bad-vw-boy 0 Posted September 4, 2009 so mk2 golf coilovers will fit the corrado.. Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted September 4, 2009 VR6 coilovers are specific however, as they will have a stiffer spring rate on the front struts to compensate for the extra weight of the VR lump. Quote Share this post Link to post Share on other sites
Jonny777 0 Posted September 7, 2009 bad-vw-boy said: so mk2 golf coilovers will fit the corrado.. Yes dude. :) Quote Share this post Link to post Share on other sites
bad-vw-boy 0 Posted September 7, 2009 Sweet i picked up a set over the weekend , however the set i have on the rado are bilstien and i cannot seem to get the top mount off as no tool can reach the 22mm nut as well as the hex 7mm key as well ....is there a knack for getting these off...in the past the cup they sit is shallower but these are very deep???? :scratch: Quote Share this post Link to post Share on other sites
bad-vw-boy 0 Posted September 14, 2009 all fitted...wow what a difference....a bit on the hard side, but deffinate improvement... :salute: :clap: Quote Share this post Link to post Share on other sites
