MikeVR6
EBC Brake Calipers
Ah, Winter again and my rear brake calipers have seized for the second time on three years. Fantastic engineering. :mad:
I know that MK3 Golf calipers are better made and a straight swap.
But has anyone tried EBC Calipers as detailed here
http://www.needforspeed.co.uk/pages/sbv_pl.asp?Vehicle=VWCOR01&PartType=BRE07
Just noticed that they're around the same price as Genuine VW ones.[/url]
im in the same sitch. i replace one last yr and now im gonna replace another.
Are the mk3 ones a straight swap?
think ill just get a standard one anyway
I think MK£s are the same. The 38mm ones. There is a bit of messing about if you are putting them on an early MK2 but they should go straight on a C.
You can get seal kits for later ones, if you have the time/ability to pull them apart yourself.
Gavin
MK4 calipers are even better as they're alloy and less prone to seizing.
They are a bolt-on mod but you need to make up some differnt brake lines apparently, which shouldn't be too bad a job.
I think they're only around £50-£60 each from the dealer.
K
The Mk IV calipers are made of alloy so do not have a tendency to seize up. John at JWR (16vG60 on this forum) fitted mine to my C after the old calipers seizing twice in two months. The only change i beleive has to be made is to enable the calipers connecting to the brake line using a Banjo clip. The old carriers are reused!!
Cheers
Woody
