chris001 0 Posted November 5, 2009 Hi, Could someone please tell me how to get one off the front fog lights out ? The bulb has gone and needs changing ! :confused4: Prob really easy once you know but prob break something messing with it ! :) Any help appriciated Quote Share this post Link to post Share on other sites
jaded2882 0 Posted November 5, 2009 Flat head screwdriver between fog and indi, then lever indicator out, it's just on metal clips. Then you can get at the screws to remove fogs and plastic bit. Quote Share this post Link to post Share on other sites
millerman 0 Posted November 5, 2009 or if its a later corrado then the same for the indicator and then you need to unscrew the plastic surround and then you can change the bulb :D Quote Share this post Link to post Share on other sites
chris001 0 Posted November 5, 2009 Thats brill, cheers both ! :D Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 5, 2009 probably too easy to remove the indicator that is...good job theives don't know Quote Share this post Link to post Share on other sites
