Bobbywhacker 0 Posted January 16, 2004 Hi all, Thinkin about doing the often mentioned brembo conversion to my beloved VR6, just one and ONLY one question... if I have to drill the brakes in order to make them 5stud fitment, aren't I going to be lowering the integrity of the disc itself? Obviously you can get cross-drilled discs, but the holes in those are never as big a wheel bolt are they Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 16, 2004 I think you use Golf 4 Motion discs with custom brackets with 5 Stud Brembo conversions.....Mike Edwards knows a lot about these conversions so hopefully he'll cut in and correct me if I'm wrong. K Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 you need the kit off a seat leon rather than the seat ibiza as the leons are 5 stud Quote Share this post Link to post Share on other sites
Henny 0 Posted January 16, 2004 you don't need to drill 'em for 5 stud fitment, just buy the Leon disks instead as they are the same 5 stud pattern (5x100) as the VR6... The part numbers for both 4 and 5 stud versions are in the BIG thread about the conversion... 8) *Edit* Woah, great minds and all that! :shock: :lol: 8) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 16, 2004 What's the minimum wheel size for this mod? 16" isn't it? I've considered doing it as the VR brakes aren't that good tbh but I can't justify the expense of bigger wheels really :? K Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 I know you can use the leon 5stud ones, but aren't the disc diameters bigger than the ibiza's?.. therefore not fitting in the ibiza calipers.. or is it best to use the whole leon setup? I did read up on the BIG thread, but seems a bit unclear when you get to the end of it Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 you use the leon set up Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 super expensive right? Quote Share this post Link to post Share on other sites
Henny 0 Posted January 16, 2004 kevhaywire said: What's the minimum wheel size for this mod? 16" isn't it? I've considered doing it as the VR brakes aren't that good tbh but I can't justify the expense of bigger wheels really :? K yeah, SOME 16" wheels will clear, but the design of the wheel is the critical part... If the spokes curve in from the center then the odds are that no wheel of that design will clear the caliper... I know that Borbet C 7.5J 16" will clear with the use of an 8mm spacer as that's what I'll be running my car on and I tested it before I bought the brakes! :wink: 8) Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 will 17" TT competitions clear them? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 not sure,i wouldnt of thought it would be THAT much dearer than the ibiza kit,if you decide to go ahead with it let us know how much they are because im thinking about doing it myself Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 will do...... think it deserves the BMC treatment 1st... and a major service! Quote Share this post Link to post Share on other sites
Henny 0 Posted January 16, 2004 I'm pretty certain that you use the Ibiza set up, but just get some 305mm diameter disks off a Leon... It's either that, or the Leon and the Ibiza both use the same caliper and size disk, which is how I read that thread... Have a word with Bill over at Badger5, that's where I got my kit from... Slightly cheaper than dealer prices, and you get the braided front flexy hoses in with the kit.... 8) Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 go for the turn2 cold air induction mate...looks a lot nicer Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 Call me a pikie if you must... but does it make 'the sound' aswell? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 yes it does,looks nice aswell Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 who sells the turn2 systems? Cannae find them anywhere on google Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 turn2 are a us company,id give you the link but ive had a new pc and all my links are on my old one Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 16, 2004 (in best Homer voice) DO'h! Off down the nuclear sub now, cheers 4 the advice boys Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted January 16, 2004 http://www.turn2usa.com/ here you go mate Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 16, 2004 Bobbywhacker said: will do...... think it deserves the BMC treatment 1st... and a major service! I've been in a VR with the BMC & a Schrick....I think you'll like :lol: Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted January 16, 2004 would the capipers from the brembo ibiza kit mount on the vr6, i heard the mounting points for the vr6 are different to other corrados? Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted January 16, 2004 i also thought the offset is different on the vr6, so that would cause problems aswell wouldnt it? Quote Share this post Link to post Share on other sites
Bournemouth James 0 Posted January 16, 2004 i was thinking of buying this conversion for my 4 stud corrado, but i also want to convert to 5 stud using eurospecs custom hubs, so i will have to get the discs drilled to 5 stud aswell, cause i cant find anyone who sells 305mm disc in a 5 stud Quote Share this post Link to post Share on other sites
Bobbywhacker 0 Posted January 17, 2004 I wouldn't know about caliper mounts to be honest.. I heard you just used the leon/ibiza mounts and they fitted straight on.... I think there are issues with the offset... I think you have to run 35-38mm or something ... offset is still a bit alien 2 me, used to own a Nova after all! Quote Share this post Link to post Share on other sites
