fla 9 Posted December 23, 2009 My heater panel operates intermittantly between all speeds and then just on 4. It was stuck for a while so i took them apart as i had replaced the thermal fuse recently. Anyways, this is a potential repair option if you find your thermal fuse is ok: Need to remove this bit with a small screwdriver ETKA Corrado.pdf19122009796.jpg[/attachment:1knyb16y] Crappy pic but the black tab in the middle is what you need to push in to pull this bit out stromlaufplan_gamma4.pdf19122009789.jpg[/attachment:1knyb16y] removed from heater control: stromlaufplan_gamma4.pdf19122009791.jpg[/attachment:1knyb16y] Spades other side connect to the upper portions, the slider connects these to the top copper arc to give the different speeds Corrado92.pdf19122009793.jpg[/attachment:1knyb16y] this is the main contact wiper and needs to contact both the upper copper arc and the lower speed contacts. This either gets pitted or deformed resulting in no fans at low speeds. Give it a clean witha file or emery paper and tweak it slightly to ensure a good pressure both top & bottom passat climatronic wiring diags.pdf23122009811.jpg[/attachment:1knyb16y] ready to refit speed control portion climatronic wiring-Golf from May 01.pdf23122009820.jpg[/attachment:1knyb16y] Quote Share this post Link to post Share on other sites
8vMatt 1 Posted December 23, 2009 Might have to have a look into this to see if the reason my number 2 position doesn't come on can be solved in the same way. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 23, 2009 Me too, my speed no.1 isnt working. One of a few problems im having at the moment :( Quote Share this post Link to post Share on other sites
fla 9 Posted December 23, 2009 What i would also suggest is prior to removing the contact in the dial, check for continuity between the dial contact and each of the upper and lower contacts - ie connect your ohm-meter to the dial contact and the upper copper arc. Move the dial to each speed position, you should have no resistance. If there is it means the upper portion of the dial contact needs cleaning/adjusting. The lower one iis a bit more fiddly - again connect one end to the dial contact and the other to each of the contacts in the removable portion. You will need to use pointed leads on the meter. This will identify whether the lower part of the dial contact is ok. Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted January 19, 2010 I have the same problem on my VR6 - heater fan only works on setting 4. Thanks for the info here..... i'll give it a try when the weather cheers up a bit. :notworthy: :grin: Quote Share this post Link to post Share on other sites
g900 16v 0 Posted June 15, 2010 this is for the later corrado ? does it work on a early one thanks Quote Share this post Link to post Share on other sites
fla 9 Posted June 16, 2010 Dont really know what the early one looks like tbh. Sorry. :( Just another suggestion for those who ahve this issue - check the brass rivets to which the thermal resistor is fixed. This sits in the resistors in the circualtion fan housing itself. Might look ok, but there may be a minute amount of clearance giving an open circuit. Its the bit to the left of the picture, where i've fitted the brass connecting block. This gave me no end of grief for ages, as it just didnt occur to me that there was a gap here. Also worth checking the other side too. HTH Quote Share this post Link to post Share on other sites
Akinesis 0 Posted July 1, 2010 This worked fantistic! It fixed the problem - you're a star :clap: Quote Share this post Link to post Share on other sites
Ben-B 0 Posted July 28, 2010 Is this the only cause for heater fans only working on 4, or are there other possible causes? Quote Share this post Link to post Share on other sites
fla 9 Posted July 28, 2010 can also be the thermal fuse failing - just desolder and resolder a new one in. Quote Share this post Link to post Share on other sites
Ben-B 0 Posted July 28, 2010 fla said: can also be the thermal fuse failing - just desolder and resolder a new one in. Is that a big job? Any tutorials on here for that? Quote Share this post Link to post Share on other sites
fla 9 Posted July 28, 2010 mine is stlightly different as i have aircon, but the principle is the same. I posted some pics up in another thread, cant remember what it was called though :shrug: Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 28, 2010 wiki how-to: http://wiki.the-corrado.net/fan_speed_t ... epair.html Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted August 14, 2010 davidwort said: wiki how-to: http://wiki.the-corrado.net/fan_speed_t ... epair.html You sir are a genius. I didn't realise that the knobs for the control panel of the heater had their own place. My entire dash was taken out by the garage for a new heater matrix about 18 months ago and when i got it back, the heater would only work on setting 4. So i tried switching round the dials last night and hey presto - fully working blower on 1,2,3 and 4 again!! The garage guys must have put them back in the wrong positions. Muchas Muchas Gracias!! :notworthy: :notworthy: :salute: Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted August 27, 2010 WAH!!! The bloody thing is only working on 4 again. :confused4: Not impressed. :( Quote Share this post Link to post Share on other sites
Diesel Junior 0 Posted December 5, 2010 This is a you-know-what of a job. For me 9 times out of ten the fault is with the slider and a few hours (......) gently bending it to improve the contacts has done the trick but be very careful as (at least here in Spain.......) it cant be bought separately, only with the head unit at €327............ Quote Share this post Link to post Share on other sites
adolf1976 0 Posted January 8, 2011 tried this but still no joy. Does anyone know if a mk3 golf unit fits Quote Share this post Link to post Share on other sites
Diesel Junior 0 Posted January 13, 2011 Am pretty sure it does but would get a Mod view if i were you before splashing the £ Quote Share this post Link to post Share on other sites
Stonejag 10 Posted August 19, 2011 Can you get the fan dials off without taking the whole unit out of the dash? Mine seems to be holding half the dash in - it's the only bit that doesn't rattle so I don't want to fiddle with it more than I need to! My fan only worked on 4, I put a new thermal fuse in (right pain of a job - previous owner had smashed the lower half of the duct the fan plugs into and it was held together with cable ties) and now it works on 3 (full speed) and balanced on the detent between 1 and 2 (lower speed). I'm not convinced the fan is the right part as it apparently came out of a Jetta - plug fits on snugly though, maybe the wiring's a bit different? Fingers crossed it just needs the contacts bent a little... Stone Quote Share this post Link to post Share on other sites
Swompy 0 Posted December 9, 2011 Will be trying this later, I now have a working fan but only on number 4 :D Quote Share this post Link to post Share on other sites
FenderSi 0 Posted May 5, 2012 I have had the parts to do this for AGES sitting in a folder upstairs. Just did it all in 20 minutes and have a fully working fan on all 4 settings. Fantastic!! For anyone who doubts how easy it is - I'm not confident to do much work on my own car yet but seriously give it a go!! Quote Share this post Link to post Share on other sites
alexvr6storm 10 Posted May 9, 2012 Hasan, Followed you guide on replacing thermal fuse on resistor, still only got speed 4. Is this the next thing to look at, when i turn the dial between the speeds it feels quite loose, doesn't really 'click' on any of the speeds... Quote Share this post Link to post Share on other sites
fla 9 Posted May 10, 2012 yes. The thing with this is the actual bend at both ends of the contact. If you can post a pic of the copper contact on yours we can have a look at it and go from there. Also, the profile in contact with the control panel needs to be smooth else it'll feel as though the switch has sandpaper in it! Quote Share this post Link to post Share on other sites
alexvr6storm 10 Posted May 11, 2012 OK, am away all weekend but will take out controls next week and post pix, cheers mate. Quote Share this post Link to post Share on other sites
