bigrichi
products to repair cracked splitter??
After the weather we've had it seems my snow plow 90mm spoiler has now got a small crack in it.
Can anybody recommend a product which will repair it??
Or would strong super glue be ok??
Something readily available from likes of Halfords or B&Q would be better.
Cheers
try some plastic welding, that might do it
Cheers for the quick reply but forgive my ignorance.....what the hell is plastic welding??
Something I can do on the drive way??
Cheers
http://www.youtube.com/watch?v=eq9TdHB73p0
this is a vid of a plastic welding tool, but you can use anything as long as it melts the plastic, Ive used a soldering iron, you'll need extra plastic though to use as weld.
just an idea. theres also strong glues that'll work to I imagine
LOL...think I'd be better sticking to some kind of glue product or i can see me having to buy a new splitter
Hi, there is a glue available called Q-BOND, that comes with a plastic powder that you put on the crack then apply the glue, its very good, i use it when i cant get the plastic welder into the area required, never failed. just be sure to follow the instructions or you could end up as part of the splitter :grin:
si.
P.S do the repair at the back of the splitter not the front if you can. looks better. :)
or you can use bi-component epoxy glue. I repaired my splitter with this glue and hasn't cracked after some (really) (hard) bumps hitting the splitter
si.
Good shout with doing the repair from behind...is this stuff easily found?? wont need to go hunting the world will i??
Funnily enough I have just repaired my split splitter this weekend. Camberly Auto factors sell 'Q-Bond'. It's really good stuff!
Apparently they also sell the Q-Bond glue on its own without the plastic powder.
If the crack is quite new and clean you shouldn't need the powder compound pack as the powder almost acts as a gap filler.
I think the glue on it's own is around a fiver and the full kit 15.
Hope this helps, good luck.
Chris
Chris
cheers all...I'll have a trip to my local factors over the weekend
